Question about Canon PIXMA iP4000 InkJet Photo Printer
How do you replace the printheads on a Canon ip4000?
I would like to remove the printheads on my Canon Pixma ip4000. It's not obvious to me; could someone please tell me how to do that?
Thank you.
  • Paul Demmitt Feb 25, 2008
    Thank you! So simple, but not so obvious. Thanks again. I wanted to clear the nozzles.
  • Anonymous Mar 18, 2014
    canon mp560 Keeps telling me that there is a fault with the printhead and to replace it
  • 30 Answers
When you open your top cover (with power on of course) your print carriage will move across to the centre of the printer. Remove your ink tanks (same way you always would) and the place where the cartridges sit is actually your printhead. To remove it you need to lift the small gray arm on the side of the carriage upward. Now the printhead itself will just slide out. Replace with new one same procedure as removal reversed.
Posted on Feb 25, 2008
I am getting 5 flashing yellow lights. As far asI can tell from the manual it appears I will need a new print head. Can it be cleaned or is it done?
Yes, that is a printhead fail. Printheads are almost as expensive as a new printer for the Pixma iP4000. You can find the printhead on eBay, runs $50-$80. Better to put that money towards a newer printer. You can also look for scrapped or damaged i860, iP4000, MP780, MP760, MP750 model printers and salvage the printhead from those.
Mar 18, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
It stopped printing black, I cleaned everything then it stopped printing color. Then it will not print anything. I have ran the color and black clean up program at least 10 times, nothing works. Any...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Feb 10, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I am receiving "Service Error 6A00" in print log when using my Canon PIXMA iP4000 Printer
That error means either a paper scrap is blocking the cleaning assembly on the right where the printhead parks, or the gears are worn out in that assembly. It's called a purge unit and runs around $30.00.
Dec 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Won't print black
If it's a Canon cartridge, make sure you remove the tape over the vent hole on top, try a couple of deep cleaning cycles, otherwise you need a new printhead, qy6-0049-000 around $40.00
Jul 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When printing pictures, there are faint white vertical lines on
Cleaning usually doesn't help that printhead much. A new one QY6-0049-000 is around $40.00. You remove by lifting the gray handle on the left after removing all the inks.
Jun 30, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Reset the ink waste tank code, and now pixma ip4000 won't turn on
Try removing the printhead and power up, if it works you need a new printhead. Many times when the printhead goes bad the machine won't power up.
Jun 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon printer ip4000 power button keep flashing 1 green & 5 yellow flashes. What is wrong ?
It may indicate a printhead error. Look at the followng instructions at the Canon website:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
Apr 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000
I think there is ink contamination on the bottom of the print head. Remove all cartridges and then remove the print head. Wash the bottom of the printhead with hot water. After that dry with a cloth. Make sure its fully dry. (Toiletpaper does a good job of drying the printhead). Make sure no ink is leaking out of the cartridges. Replace everything and then run a deep cleaning test.
Good Luck
Hope this helps
Thanks for reading!
Apr 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma iP4000 problem
the printhead is shot. I've replaced my printhead twice on my pixma ip6000D in just over two years.
Aug 20, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
345 people viewed this question
old marine
old marine
