Question about Jensen VM9411 Car Video Player
Jensen model#vm9411 Ive got the vm9411 and it was all hooked up and about 20 sec into the dvd it will flip to a blue screen why?
  • perm Feb 25, 2008
    Help me fix it?
  • 1,586 Answers
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the blue one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
Cd/dvd will not load all the way in
i have a vm9311ts jensen and just hooked it up from storage it wont load cd in all the way any help out there
Aug 15, 2010 | Jensen VM9411 Car Video Player
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Tv has sound but no picture
Should be the same bypass. Do you get any message when you put it on a TV station? Guess what, after Feb 17th, it won'y matter anyway unless you're going to get a digital converter for it!
Try grounding the pink brake wire and see if that does anything. As far as I remember, that bypass is for ALL video on the screen. Let me know.
Peace,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Jensen VM9411 Car Video Player
JENSEN VM9311TS DO I HAVE TO HOOK THE BRAKE WIRE UP AT ALL?
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Jul 26, 2008 | Jensen VM9411 Car Video Player
Bypass code
Jul 15, 2008 | Jensen VM9411 Car Video Player
Jensen Model Vm9411
take it to a repair shop to clean the lazer probably is dirty.
Jul 03, 2008 | Jensen VM9411 Car Video Player
How do you install the dvd portion so i can view movies
I have Jensen VM9411 I put code 1264 and disable my remote control now is not working and my screen is not working
Aug 22, 2007 | Jensen VM9411 Car Video Player
Jensen vm9411
if you are sing the single blue you need to slit that with a male to two females then hook up both L and R to the female connectors. Hope this helps
Mar 24, 2007 | Jensen VM9510 Car DVD Player
My Video does not work on my Unit
Actually you don't need to do all those stuff.... there's a softcode hack for this one. it would enable you to even play pirated DVDs as well.... ATTENTION TO ANYONE WITH A JENSEN VM9311,VM9411, VM9511TS and/or 9021TS YOU CAN BYPASS THE PARKING BRAKE SECURITY FEATURE FOR FREE!!!! WITHOUT PAYING FOR THOSE PULSE BOXES OR ANY ADDITIONAL HARDWARE!!!!! YES THE LITTLE BLACK BOXES WORK....BUT THEY'RE A SCAM CAUSE YOU CAN DO THIS FREE USING THE JENSEN FACTORY OVERRIDE CODE So if that isn't clear enough, let me further explain. The code is a permanent way of disabling the brake override on the jensen vm series multimedia head- units. There are two ways of doing this: Insert the DVD After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah" 1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen. (What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.) 2) Next, on the main remote press stop twice, then 1, 2, 6, 4. You will now see a hidden menu that says: Region Code Brake Override (I know you're drooling by now) Macrovision (Watch all the burned and pirated movies you want if this option is off) Loader Version Model Version 3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want. This is what you want: Region Code: 1 Brake Override ON Macrovision: OFF When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving..... The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly. 1) Insert the DVD and you'll get the blue screen. (If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.) 2) On the main remote, push stop twice and then 1, 2, 6, 4 3) Push the joystick on the unit SOUTH twice and then click it once. 4) Press SYS SETUP on the main remote twice to save your settings. It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing. I tried to make this as clear as possible. If you have questions, private message me or post here. Best of Luck! By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Sep 05, 2006 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
126 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
