Question about Sony Handycam DCR-TRV25 Mini DV Digital Camcorder
TRV25 error C:31:22
When I rewind I get this error message and it beeps. The tape will not eject. If I remove and replace the battery the tape will eject but when I rewind I get the same message????
    President:
  • 4,402 Answers
Try hitting it on the side kinda firm.
Posted on Feb 25, 2008
Sony trv25 cassette does not eject
These can have ls chassis failure causing the tapes to jam in the set. Can be repaired under $200 in most cases. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Apr 22, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Error MSG when rewnding
that's my problem too. I'm going to try the solutions for the "remove tape" problem when trying to record--use dry head cleaner and the other options, check out that thread,
Feb 21, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Sony DCRTRV 25 : Getting 31:23 error message
possible pinch roller problem.The pinch roller rubs against the capstan motor to pull out of the cassette .This pinch roller seems to fall completely or loose causing the error.The other possiblity is that the capstan motor is not turning ..might need repair..
Nov 29, 2007 | Sony Handycam DCR-TRV25 Mini DV Digital...
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
Has error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam DCR-TRV25 Mini DV Digital Camcorder Logo
259 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
