Question about 2wire 2700HG-B Router (2700HGB)
Can u provide me with the best wireless router on the market as i bought 3com 3CRWDR200A-75 and i faced alot problems with it is the the 3com good well and what's the best as i'm trying to get best ot better one
  • haithoma22 Feb 25, 2008
    is it better than 3com or the same performance, and i heared that the linksys notworking automatically when windows starts, i mean with not working automtically that each time starting windows i should connect as a dial up from my pc is it right or wrong
    other thing is linksys provide me along range and what's standard range for any wireless, on the mean time i need to extend my range how can i make it without much cost. and i heared from other one that i can plug my wireless router to external Tv antinna or dish, sorry if my question was silly or something but those what i'm looking for with my wireless router
  • 34 Answers
I have a Linksys Wireless-G WRT54GS(any Linksys wireless g or n unit will be good.) This one has speedbooster.
Posted on Feb 25, 2008
  • 1 more comment
  • Chris W
    Chris W Feb 25, 2008
    Lynksys products work great for me(Untill power outage messes it up, but unplug it and plug it in it will work again) Dail up today would take about 2 minutes per page. Lynksys is great quality, i will not use any other anymore.
  • Chris W
  • Chris W
    Its wireless range...I get it to work at 45 feet through 3 walls at 89% signa l strength. No, you dont need to. Nor can you. You can buy 3rd party mods, or install a hack for extenden range, but it comes at a price, it heats up ALOT, any dust will be serious touble, and the heatr can ruil the unit.....and thats coming from someone who loves to hack.
Configuring a 3COM 3CRWDR200A-75 router as a repeater
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to then the repeater router should use a higher number (ie. 10), such as or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
3COM 3CRWDR200A-75 Firmware Download - All Versions
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
Ugrade 3com router 3CRWDR200A-75
The first thing I would check would be in the configuration (point your web browser to when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
Mar 24, 2009 | 3Com OfficeConnect Wireless Router
i am not sure of this, however try this link this might help - 375k
Mar 17, 2009 | 3Com OfficeConnect Wireless Router
3com wireless router and Sympatico
well you could probley find a better router that the model you have it is probey a older model and probley will not work on some computers.
Jan 03, 2009 | 3Com OfficeConnect Wireless Router
3com 3CRWER200-75 wireless router won´t connect to certain sites
first coonect your wifi router witjh your laptop with ether net then go to this link
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
Nov 03, 2008 | 3Com OfficeConnect Wireless Router
How to put wep password for 3com 3CRWDR200A-75...
all the documentation is here and the installation software if you need it is at the bottom of the page
Sep 06, 2008 | 3Com OfficeConnect Wireless Router
3com 3crwdr200a reboots every 30 minutes
The 3com website is remarkably shoddy on this issue, and doesn't have the newest required updates. Even the KB on their site is thin on solutions.
You really need firmware 3.6.4, yet 3.0.1 is the latest on the official website. Try this page:
for the very latest firmwares, and note that it's best to clear out the router memory completely before adding the new firmware to it. This is because it sometimes doesn't like the new image files otherwise. The way I suggest:
1. Note all of your settings manually (don't save a config file, it may not read back in).
2. Hard reset and clear the memory, by holding down the reset button and powering on.
3. Connect to with your browser - you may need to mess with the network settings on your PC to get it to connect. You will see a very bland screen, asking you for a firmware file, rather than the traditional login screen.
4. Upload the latest firmware, downloaded from the site above.
5. Allow the router to do it's business and restart.
6. Connect back to, and you will once again see the correct router software, with a new install wizard.
7. Re-enter all your settings, as noted above.
May 04, 2008 | 3Com OfficeConnect Wireless Router
Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
161 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
