Question about Panasonic PV-V4523S VHS VCR
VCR acting strange with audio and playing
I put in a tape to watch in my VCR and the audio was sounding a lot different, the sound would turn off then turn on. And when it's on, the sound is a lot different than what it used to sound.
PLEASE HELP!
    Problem Solver:
  • 15 Answers
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Posted on Feb 27, 2008
I have no picture no sound vcr shows its playing
clean vhs head with q-tip and rubbing alcohol gently, or buy blank tape and put it in play in sp mode acts as a dry cleaning tape.
Mar 16, 2012 | Sony Televison & Video
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Jul 08, 2009 | Televison & Video
No sound on VCR
if you get sound from anther recorder that tells me that the head on the current vcr is working, which leaves just the output, if using a antenna switch to channel 4 if using 3 (theres a little switch in the back) if you are using 4 change to 3, if your using audio output cables swap them with a good working pair.
if all is good it would require service (unless the mute is pushed)
good luck
please mark the post with a fixya
Feb 19, 2008 | Televison & Video
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
SANYO VCR VWM-900 playback is jerky
Your post/description indicates that possibly the brake mechanism of the supply reel is acting up. A typical VCR has 2 reels inside that spins the tape. The left side is the supply while the right is the take up. If the brake (on the left/supply) is engaged (even partially), then the entire mechanism would have a hard time pulling the tape around the video/audio head and would partially be stretching. This would represent itself as jerky audio/video in most instances. There would possible also be a low screeching sound coming from the machine/tape. An indicator would be stretched tape - there would be uneven edges of the tape.
Since this is an electro-mechanical problem, perhaps your best course of action is to seek the services of a qualified video machine technician.
Alternately, it may be possible to loosen things up by first fast forwarding the entire tape and thereafter rewinding fully before you play it.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
Sound only works when vcr is turned on
When not watching a tape, be sure power is off ( VCR ).....
How is the picture...? When you watch tapes, do you put the
TV on channel 3 or select video..? Also, what is signal source ?
Cable ? Box ?.....................T.
Dec 05, 2007 | Panasonic CT-27G13 TV
Playback sound
Unit might be picking up 60 cycle hum or other electromagnetic field. Is VCR sitting on/under another piece of electronic equipment? If so, it could pick up such from the power supply circuitry of that other device. Try moving the VCR away from other equipment and see if the unwanted sound disappears.
Mar 09, 2007 | Philips VR550 VHS VCR
Unable to record or playback VCR tapes
All you can do by yourself unlesss you are a tech. Is run a head cleaner tape through it. It sound like a dirty head to me. Here is something a lot of people do not know, The video head and the audio head in a VCR are two separate heads. thats why you can loose picture and not sound. Best taken apart and cleaned manually with rubbing alchol but not advisable if you are not experienced due to high voltage and if cleaning improperly you can damage the unit worse. Good Luck
Nov 25, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Panasonic VCR pv-7451: No sound in "normal" mode
Are these prerecorded tapes or ones that you recently recorded? Or are they all normal audio tapes?? Try a pre recored and turn off the HI fi audio and thats an easy thing to do as put it in normal and mono.. Get back to us so we can assit. Not enough info as could be 100 things.
Jun 28, 2006 | Panasonic PV-7451 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic PV-V4523S VHS VCR Logo
142 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
