DVD player tray will not open
My DVD player tray will not open. I have consulted the hard-copy manual and it does not provide any useful troubleshooting information or anywhere within the manual. Here are the DVD player details:
Make: Sonic Blue, Go-Video
Model DVR4200
Thank you for your consideration, and I look forward to your reply.
  • 1 more comment
  • cadetval Feb 26, 2008
    There is no sound which indicates it might be "jammed" and there is certainly nothing in front of the device preventing the tray from opening. Is there any trend of this DVD player's tray malfunctioning?
  • goldhunter52 Dec 11, 2008
    I have a GO VIDEO VCR/DVD player and it won't open either. Don't know why.
  • Laura Apr 03, 2013
    I also have a dual VCR player - the tray on the right which houses the old type format (not the C) opens but the left which houses CD's does not open
Maybe this will help someone look in the right direction. A friend gave me a KISS DP-1000 with the same problem: The TV showed the 'Eject' graphic, and nothing happened. There is no little hole that you can poke a paperclip in, like on a PC. I opened the player, and still could not find anything. Then I googled the model of the actual tray mechanism (DSL-710A). The datasheet said that it did have an 'emergency eject' machanism, operated by a Philips screw at the bottom of the tray. There are no holes at the bottom of the DP-1000, only a dimple that dead-ends. I broke through the bottom of the dimple with a small, flat, screwdriver, then enlarged the hole. I felt around with a medium Philips and it fitted into something. I twisted gently, and the tray popped out. Why KISS covered the 'emergency eject' screw is anybody's guess, but I am not buying any of their products.
Posted on Feb 28, 2009
    Problem Solver:
  • 6 Answers
DutchDouwe is correct, On the bottom of the actual tray mechanism (DSL-710A), there is a white plastic phillips-head slot that when turned clockwise will release the drive tray. However, I do not recommend "punching" through the case as you may damage the sensitive circuit boards inside. Instead, unplug the device from the wall and simply remove the screws on the case. Once inside, remove the screws holding the CD-ROM (yes, it is a CD-ROM and can be plugged into a computer using the IDE interface and used as such) to the case and simply turn it over. Locate the white plastic phillips-head slot and turn it clockwise with a screw driver.
Posted on Dec 06, 2009
I have Sansui DVD 512 model. When the DVD/Cd is closed by the tray it does not play and eject the tray. The local mechanic asked me to change the tray becoz after closing the tray the lens does not raised due to the tray mechanism fault. The tray is not available in Kolkata market. What can I do ?
Posted on Jun 24, 2010
  • 76 Answers
Usually when the tray gets stuck it means it was jamed by something or something is in the way for it to open. Hope this helps. =)
Posted on Feb 25, 2008
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
The DVD loader will not open. The DVD player has never been used.
There seem to be a prolem with the mechanism that opens and closes the player.
Probably the player hit something really hard.
To fix this, all you have to do is to get the appropriate screwdriver, unscrew the cover of the player, take a close look at the mechanism that controls the disc tray and you will discover the fault.
Adjust the rubber and sit the tray properly, if you see any damage on the mechanism, all you have to do is change the mechanism.
Try to open it before you cover it back.
Take care
Jun 15, 2010 | RJ Tech RJ-800DVX DVD Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Does not recognise either new disc or pre recorded disc dvd or cd
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the player that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Sanyo DRW-500 DVD Recorder
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Disk Tray
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Sergio
Mar 29, 2008 | Sony RDR-HX825 DVD Recorder/HDD Recorder
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Televison & Video Logo
1,850 people viewed this question
Top Televison & Video Experts
