Question about Crosley CE35100AA Electric Kitchen Range
Beeping problem i pressed the button with the running man symbol and now my range wont stop beeping. i unplugged it and still wont stop beeping when i plugged it in. it reads 0:00
  • Anonymous May 28, 2008
    MY CROSLEY IS CE38600AAV It has the beeping sound and the oven will not work. The control panel is out of wac . I need to know why and I cannot bake I need to bake
  • Anonymous Jul 11, 2008
    I have the Crosley oven and I constantly need to unplug it or the beeping continues. I also cannot use the oven at times and do noot know if this is related. PLEASE help!
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
Buttons/timer don't make sound
Unplug the range.
Remove the control panel to access the touchpad and electronic control.
Remove the touchpad ribbon from the control inspect for and clean any corrosion and reinsert it.
If this fails, replace the touchpad.
Feb 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My printer wont stop beeping
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
Use it will work..........
Good Luck
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
