Tape recorders. Both of the twin tape recorder-players are not functioning. NB. This is a multi-function unit which incorporates an AM/FM radio, twin tape decks and CD player/16 programme memory. Twin speakers.
    Sergeant:
  • 395 Answers
What is the make and model of the unit ? so little info. but my best guess is the motor, or belt. best probibility is the drive belt is shared by both decks therefore the tape decks woun't engage or move the tape along the tape path. look for broken belt inside or a belt that is slipping. the model # would be helpful to find the part # you need or for that matter the size of the belt ( to order PRB belt equiv.)
Posted on Feb 25, 2008
    Brigadier General:
  • 6,966 Answers
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 25, 2008
    Glad to be of assistance and appreciate the rating.
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
Tape is not set on record when it is set on record
hi,
it sounds like the tinny switch that detects the "safe" function is broken... normaly it is a little plastic "finger" that is pushed when in safe mode and stays in place when in record mode...
Apr 09, 2014 | Sony Hvr-m25u Recorder Player 1080i Hdv...
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
How do you start a tape to play ok..i turn on...put in a tape....now, how do i get it to play
Look for a symbol that looks like this >I. or just this>, and push. Make sure you have selected "tape" function
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
Recording on tape deck
I have not "solved" the problem. I'm simply assuming that the built-in microphone does not work. I CAN record radio on to a tape and a CD onto a tape. I just cannot record my voice onto a tape. I'm just chalking it up to a faulty microphone.
No, I do not want a plan, thank you.
Mar 31, 2008 | GPX BCD2805 Radio/Cassette/CD Boombox
Taping VHS to DVD
this unit does not have a dvd record function. you will need a dvd recorder.
May 24, 2007 | Sansui VRDVD4001 DVD Player/VCR
 Grubhead
Grubhead
