Question about Sony MEX-DV2000 CD Player
Dolby 5.1 Videos won't play correctly, no voice sounds come out.
Installed in a highend 5th wheel RV as part of the TV DVD player system. Stereo Surround sound movies works but EX 5.1 Surround Sound does not let the music plays the speaking parts. RV dealer is baffaled, Had an engineer look at it and can't figure it out. Sony said it is the installers problem!
Yes
Posted on May 29, 2008
Do you have 5.1 speakers with built in amp?
Why won't my DVD player play DVDs
Have you verified that the actual rca cables are properly connected to the dvd stereo system and to the tv as well? You must also make sure that the out put for the stereo is set and the input source on the tv are set correctly. I know that there was an issue with a DVD stereo system manufactured by Lippert that required a software update for it to work correctly.
Jun 11, 2014 | Cruiser RV Enterra E-29RBS RVs
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
No picture, no sound
see the troubleshooting index:God bless you
No sound
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
test this steps and fix it. God bless you
Jul 22, 2013 | Televison & Video
Muffled Voices on Dolby DVD Playback
Most voices come out of the centre channel. Put your ear to that to see if it is working. If it is not then you might have somehow managed to switch it off. Check the cable connections to the speaker also.
Mar 12, 2017 | Sony Audio Players & Recorders
No English language on DVD 's
Bought a new unit. The old unit was a surround sound system in which the previous owner removed the speakers. I wasn't aware of the problem but found out that it would not allow it to play on Dolby 5.1...It would only play DVD's on channel 2, therefore no english etc. Thanks for your help!!!
Feb 10, 2010 | Koss KS4110 DVD Player
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
SUPERSONIC SC-29D There is no sound from actor or actress speak, but has back ground sound
Set sound properties to Stereo by going in to menu of dvd player as it seems its set on AC3 or Dolby Surround some thing.
Need further help, let me know.
Sep 23, 2008 | Supersonic Progressive Scan DVD Player
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Sony MEX-DV2000 CD Player Logo
844 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
