Question about Samsung HLP4663W 46" Rear Projection HDTV
Loud Cracking/Popping Sound
My Samsung HLP4663WX will intermittently just have a loud popping sound. Sounds like something is cracking in the back of it....but there are no problems with my TV otherwise. Just that loud sound...I'm curious to find out what it is? Should I be worried? Anyone know anything???
Thanks
TC
  • 3 more comments
  • BossMan74 Feb 25, 2008
    Thanks for the help accordianman. Is this common? Is there anything I can do to try and make the sound stop? It's a very loud noise. When people are in the room, they jump if they aren't used to it...
    -TC
    It's been on the stand for several months...it's secure as far as I can tell. It sits on a Bell'O stand which is made of tempered glass. Only makes the sound when the TV is on. It's annoying!!!!!
    -TC
  • angiegutterm Jan 11, 2009
    I have a 56 inch samsung flat screen tv it has started making this annoying cracking noise when I am watching it. Help
  • francisco abreu Jun 14, 2013
    [B]I found a solution to the sound problem, which was causing popping and static sound from the speakers.[/B] This was also shutting down the audio after watching TV for some time. I place a heat sink on IC 987 part number stv8258DSX. This IC controls the sound and is overheating. The cause is unknown to me. Its easy to place a heat sink. Direction: cut the heat sink to size allowing room for a nylon nut. make as tall as possible. drill hole in center, but drilling only to its center, not through it.. Use nylon screw and nut (plastic). Insert the screw through the hole in the grill cover metal and than thread the nut to it. place the heat sink on top of the IC and place the grill cover back on aligning screw in the hole. (Don't forget to use thermo compound between the heat sink and IC). pull up on the screw while turning clockwise to tighten. I left the TV playing all night to the next morning and sound remain normal. I even turn on SRS sound mode.
  • Anonymous Mar 31, 2014
    sound cracks and pops at all levels
  • 979 Answers
Any other symptoms? You may be just hearing the occasional sound of static being bled off, or, if the set is not working properly, the sound of the high voltage section trying to compensate...accordianman
Posted on Feb 25, 2008
  • Michael Borelli Feb 25, 2008
    One more thing.You could be also hearing the set "settle" on its stand. Is it secure?...accordianman
Why is my Vizio VA320M HDTV making cracking and popping sounds?
Check the speaker first. If it is found OK, Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 03, 2015 | Vizio VA320M 32 in. LCD HDTV
Hello, Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
Jan 29, 2015 | Samsung Televison & Video
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
I have an 05 Mazda 6, when my car is while idling it makes a loud cracking/popping noise.
A cracking or popping noise is frequently an indication of an air/fuel mixture that is too lean (too much air). Have a mechanic or mechanically inclined friend check the various vacuum lines on your engine. Sounds like a cracked or broken vacuum hose on the intake side of the engine. Good luck.
Oct 10, 2013 | Mazda Cars & Trucks
When pedaling starts off making squeaking sound but now it is very loud with cracking and popping.
Pedal or bottom bracket bearings need a look. The web has many resources for identifying noises on a bike. Just search for a few key words. For example "bicycle pedal loud cracking and popping"
One resource...
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Happy hunting.
Aug 18, 2011 | Cycling
Heard a loud cracking sound and the screen to my Toshiba plasma 50" went dark
The popping sounds are bad capacitors arcing at the high voltage input area. You need to change parts on the power supply and repair the high voltage control card located on the X-sustain..... or you can just order a new power supply board and X-sustain here: CLICK
Oct 08, 2010 | Toshiba 50HP66 50 in. Plasma Television
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
355 people viewed this question
Jerry Greenberg
Jerry Greenberg
