Question about Car Audio & Video
Subs i have two 12 inchsubs 1000 watts shallow baskets doul voice coils and a 1800 watt amp. iv been thrue 2 amps thay last for a day or 2 and thay go out i dont know why.checked wirering every thing ok.the amp are 2om stable and the speakers are 4om. i put a om meter on voice coils andthay showed 3.5 and 3.3 oms on each voice coil.i dont know whats going on.i have a new 1800watt amp but im a fraid to hook it up
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Posted on Feb 26, 2008
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker 12L5 blew from a kicker zx750.1
MY BEST GUESS FROM WHAT YOU HAVE SAID IS THAT THE BOX WAS TO SMALL. BUT YOU ARE OVERPOWERING THE SUB RUNNING IT AT 2 OHMS ON A 750 WATT AMP WITH A SUB THAT IS ONLY RATED FOR 600. NO MATTER HOW FAR YOU TURN YOUR SETTINGS DOWN, YOUR STILL PUSHING TO MUCH POWER FOR THE SUB TO HANDLE. IT IS ONLY RATED 600 WATTS FOR A REASON. ESPECIALLY IF YOU LISTEN TO MUSIC THAT HAS A REAL LOW END AND THEN A HARD HIT. REMEMBER A HARD HIT WILL SPIKE YOUR AMPS OUTPUT THEREFORE PUSHING MORE WATTAGE TO THE SUB.
Nov 19, 2013 | Kicker Car Audio & Video
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
I dont have any cosmetic problems with my subs .. but i have 4, 12 inch hifonics olympian subs in one sealed box. and i cant find any specs on them at all.. do you know the watts and rms wattage and how...
look on the bottom of subwoofer should say like olm2412 olm1612 olympus the 1612 is the rms and speaker size 2412 is 2400 rms and the 12 stands for 12 inch subwoofer.i think thair is only 2 modles . also u have 4 u would need a 10,000 rms amp if thay are the olm2412s or 6,000 rms amp to push 4 olm1612. as far as box building info i think you should call maxxsonnics. 847-540-7700 talk to mike
Mar 03, 2010 | Hifonics W-124 Olympian 12" Subwoofer Car...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer PremierĀ® TS-SW1241D Car Subwoofer
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
