Washing Machine doesn't spin
When the Machine gets to the spin cycle, the motor kicks on, but it will not start spinning , without starting it by hand
  • 96 Answers
Need to have the motor checked. Start windings may be weak.
Posted on Feb 25, 2008
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
The washing machine seems fine but will not start the spin cycle
Hello there, I got a whirlpool sport washer machine that is showing off code f-28 and it gets the door locked! I have unplugged it and have taken the toe kick plate to reach for the release lock. I select a cycle but it seems to send signals to the motor, inlet valves but it just stops and nothing happens,. so if you could help me I would really appreciate it! thanks joe
Sep 04, 2010 | Whirlpool Washing Machines
Gw 612 washes ,drains wont spin fault comes up as on off off off on
Hi just read your posting.Now the problem you might have, and I have had before, is the motor is not turning the bowl far enough when it is starting to spin and therefore the machine thinks the bowl is not turning.To get your machine spinning 1st undo the 2 screws under the lid so you can lift the hob up to see the bowl.Select a spin cycle and hit start while you are holding the hob up enough to see the bowl.The reason for lifting the hob instead of the lid to see the bowl is if you lifted the lid the machine would not work because of the lid switch.Now when you are holding the hob up to see the bowl make sure the lid is closed so the machine will work.Now once you have started the spin cycle you will see the bowl turning one way then reverse and turn the other way.While you are holding the hob up when the bowl turns in 1 direction help turn the bowl in that same direction with your hand.Once the bowl reverses help turning it in that direction also.This will make the machine register that the bowl is loose enough and will kick to spin.Once it is spinning let it spin for the cycle and you should be fine.Please reply for further help if needed,Good luck
Jun 16, 2010 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
I have a ge washing machine that on the spin cycle kicks on and off
Don't know the model but if it is a two speed model and is clicking off and on when set for high speed spin but seems to start up and spin OK in slow speed spin, you have a bad motor
Dec 19, 2008 | Washing Machines
Inglis washing machine won't spin
Turn the timer indicator to the asterisk * start it up. It should agitate without no water in it. If it don't agitate you have a bad coupling part number 285753 whirlpool. Google it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Washing Machines
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
