Question about Brother HL-2070N Laser Printer
Brother HL-2070N I had power outage today and after that all four lights are flashing. Any recomendation how to fix this problem? Thank you for your help, Simon
According to the brother site, that means that the printer needs servicing. I talked to a local service center and they recommended chucking the machine--any repair is likely to cost almost as much as a new printer.
It's pretty disappointing.
Posted on Apr 15, 2008
I have a brother HL-2070N and all four lights are blinking.
Yes pressing the go button gives the actual error, the toner light being on when you press go tells me that there's a fuser error. Either the heater lamp is burned out, or one of the overtemp sensors has been tripped, or the power supply is not turning on the fuser. I would replace the fuser first if you have no way of testing the parts in the fuser. You can find a fuser at www.precisionroller.com
Feb 19, 2010 | Brother HL-2070N Laser Printer
My drum light keep flashing. How do i fix this problem?
if the drum light is flashing, and the ready light is on,
it means that your drum is nearing end of life and will need to be replaced soon.
thanks adi
Jan 26, 2010 | Brother HL-2070N Laser Printer
Need help resetting the drum on HP 2070N. Drum is changed. Light is still on. Thanks!
You need to have the front of the printer open, when you press and hold the "Go" button. All four lights will come on, in sequence. Release the button, and close the front cover.
Oct 07, 2009 | Brother HL-2070N Laser Printer
I bought compatible cartridge for my Brother
ok so its not a new cartridge there for 2 options remain.
1) it needs chipping back to 0
meaning its been refilled without being reset.. the little chip on the side..
2) its a dud sorry to be blunt but ppl can and will sell anything on ebay,,
hope this helps you
Sep 27, 2009 | Brother HL-2070N Printer
All four lights flash continually on Brother 2070n printer
If there is an error that cannot be cleared by the user, the printer will show that a service call is needed by
lighting up all the LEDs as below.
c5ae79f.jpg If you see the service call indication, turn off the power switch, wait a few seconds, and then turn it
back on and try to print again.
If you cannot clear the error and see the same service call indication after turning the printer back on, call
your dealer or a Brother authorized service representative.
Aug 04, 2009 | Brother HL-2040 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer leaves four blots on page
Hi all of you
If the between each blob are equal , your drum is defective,
change it.
Hope this fix your problem
thanks
Hamedo
Nov 21, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
201 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
