Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C NOT Not Printing Color Properly
I was recently printing some color labels and all was going well until the colors started coming out blue/green almost grey. I replaced all 3 color cartridges even though they seemed fine and have run the self-cleaning several times but no luck. I think at some point the cartridges were put into the wrong spots but this was remedied. Do not know if that could cause damage. I have always used the proper ink cartridges for this printer.
Thanks for your help.
  • 1 more comment
  • MOLeary Feb 25, 2008
    Thank you for you quick response. While I wanted to mention the misplaced cartridges for the sake of full disclosure, I have seen zero improvement as I have continued to try printing. I will still do what you suggest but first I need to know where the printer head is. I seem to have access to 2 areas, the wells where the cartridges go and a narrow opening the length of the printer where the mechanism goes back and forth. Can you explain further. Also, as the color is now printing practically black and whit, are there any other things to look at?
    Thanks Again.
  • MOLeary Feb 28, 2008
    I am not sure if I did it exactly right but some color did return to my prints. It is still not back to normal, however. Maybe just time for a new one.
  • Anonymous Apr 25, 2008
    I was printing and everything was coming out sepia toned. I'd filled the yellow recently, and pulled it out, turned out it was leaking. Once I fixed that problem I ran a few cleaning cycles, but now everything is printing perfectly, but I get NO blue, whatsoever. No matter what I do, the blue is gone (but the cartridge is near full). Please advise.
    Kim
    President:
  • 2,072 Answers
If the cartridges were in the wrong slots, it shouldn't take very long for it to clear up. What I don't understand is how it even ran with them in the wrong slots, but that's not the point.
Having corrected that problem, Have you run many prints after that? You may just have some remnant ink not completly out.
If thats not it, remove the cartridges, unplug the machine and very lightly dampen a lint free cloth with some alcohol and clean all the contacts in the machine and one the cartridges.
Then again run all the set up modes and see if that helps.
You should in no way have ruined the printer my having the inks in the wrong place.
One other thing you can try, And I do this to ink jet printers but hesitate to mention, but it does work.
Unplug the machine and remove the cartridges. Place some paper towels under the print head where the cartridges and slowly trickle some soapy cleaner, Like Fantastic into that area, then flush it out with some rubbing alcohol. Dry the area gently as best you can, and let the printer sit an hour or so to let any slight amount of liquid remaining to evaporate. Those inks can build up and clog that area causing lots of problems.
Posted on Feb 25, 2008
  • Rick Kasper Feb 25, 2008
    I am meaning the wells where the cartridges seat. The area where the print cartridges sit. Sounds like the absorption pads are clogged to me.I am not refering to the entire area where the cartridges move back and forth.
    If the through cleaning does not work I would suspect the head being bad. If that is the case, the price of the part probably would cost as much as replacing the printer.
    You can take the covers off the machine and reseat all the cables.
    Good luck. let me know.
  • Rick Kasper Feb 28, 2008
    You can try cleaning them again, this time use a soapy cleaner, something like fantastic instead of alcohol.
    Let it dry out a little longer then with alcohol.
    If that doesnt work then you may want to consider replacement.
    They do wear out.
How do I clean my Brother MFC 210C. I've done it before ont eh computer, but can't find where to do it this time.
Press the Ink or Ink Management key on the control panel of the machine. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set. Press Color (Colour) Start. The machine begins printing the Print Quality Test Sheet. By reviewing this Test Sheet, you can determine if the print quality needs improvement. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
The display will then show START CLEANING? 1.YES 2. NO. Press 1 (YES) and the machine will start cleaning the color ink cartridges.
Jan 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
All of a sudden my printer will not print in color.
Have you tried printing a test page and re-aligning it?
Jun 18, 2010 | Brother MFC 210C All-In-One InkJet Printer
PRINTER IS NOT PRINTING COLOR COPIES ANYMORE. INK WELLS FILLED
please check in the printer properties if the print in greyscale option is turned on
Mar 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210c-new brother ink cart-blk Help test/clean instruction ??
Press the "ink" button, you will then see "test print" on the display. Press the top of the joystick like (labeled search/speed dial) wheel until the display changes to "cleaning"; then press Set. Press Set one more time to select the color black. Cleaning should start.
Mar 11, 2009 | Brother MFC 210C All-In-One InkJet Printer
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mfc 240 c
Did you do a firmware update? If not go to brother homepage , download the update tool and do the update if it is avaiable.
Do you print with generic ink? If yes this prob is because of different color depth. Try to print with the original innobella ones or do some resettings within the printers properties when you print a pic from pc.
You may test the print out by printing directly from a picture card without pc.
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
826 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
