Question about Microsoft Zune JS8-00001 Digital Media Player
Zune 30 GB
When I press the power button I get a symbol of a battery with an exclamation point inside of it. What does it mean and can I fix the problem?
  • Anonymous Mar 15, 2009
    I plugged in my Zune to power it up, and that's when this symbol showed up (not when I tried to turn it on). I had just recharged it, so not sure why it would require recharging again if I hadn't used it...
    Problem Solver:
  • 5 Answers
Dude to fix this problem u have to charge it
smart one
plug the zune in to the usb port of a computer and turn the computer on
Posted on Nov 06, 2008
  • 50 Answers
It means your battery is dead. Plug it into your computer over niht and it will work in the morning.
Posted on Feb 25, 2008
I just powered on my Droid 2, but it isn't loading correctly. It has been on for over half an hour, but the screen is still showing just the droid "red eye" thingy. What do I do?
Sounds like its bricked. You can try to do a factory reset. 1. Turn Droid 2 Off by pulling battery.
2. Press 'X' on the physical keyboard and then Press and HOLD Power button until the Exclamation Point/Android picture shows(after motorola symbol).
3. To access menu options Press the "Search" button depicted by the Magnifying glass on the Keyboard and the menu items will show up.
4. Use the Volume Down key and select the "wipe data/factory reset "option with the Camera button all on side.
5. After thats finished, reboot the phone
Feb 18, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Exclamation point warning light came on...what
A yellow explanation point symbol on the dashboard typically applies to the Tire Pressure Monitoring system. A thick ! inside a half drawn flat tire symbol to be complete and comes in yellow color when lit. Under normal vehicle set-up, if this indicator stays lit after the power-on selftest, you need to check your tires for any uneven pressures and adjust their pressures to correct specifications. Okay? : )
A red exclamation point inside a circle when lit indicates your parking brake is on, or your brake fluid level is low.
Jun 18, 2010 | 2008 Chevrolet Trailblazer
My Zune 30GB Is Menuless...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
May 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune frozen with logo
Let the battery drain completely and then plug into computer. There was a leap year glitch from Microsoft and the fix is working today. Ours froze yesterday and it's OK this morning. This only fixes those that froze Dec. 31st.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Won't start
Sounds like a firmware issue or booting problem, you might have to reformat it then reinstall the zune firmware and reupload all you'r media to you'r zune.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
my 30gig was doing same thing i opened it up and one of cables just slipped out of port very simple to fix open you zune where the charger goes in there is a black cover remove this carefully then remove the 2 very small screws next use a very thin flat surface be very careful and you can see the edge where it seals just put you thin applient into the side and gently pull it up go all the way around once at top be gentle dont use the knife or whatever you used just slide it appart the back will come off then just reconnect cables good luck
Sep 30, 2008 | Altec Lansing M604 Computer Speakers
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
122 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
lugnuts1
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
