Unrecognizable USB External Harddrive
I have a BusLink uii-80 external harddrive with a USB2.0 connection. My PC no longer recognizes the drive, and does not give me a drive letter. If I boot my PC and plug it in, then I hear a *ding* like it is recognized but I don't see a drive letter. USB Mass Device driver is loaded.
  • paintrgrljen Jan 19, 2009
    when I plug in my card reader I hear the ding but nothing comes up on my screen
    Sergeant:
  • 406 Answers
Dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Posted on Feb 25, 2008
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
External hard drive is not being recognized by any computer
then check.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
Computer won't recognize (Vista)
First of all make sure that the USB port that you are
using to connect it to your PC is a USB 2.0 port, and
not USB 1.0.
Also if it came with an external power, connect it to
the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is
lower than that of USB 2.0 and therefore might not
be enough to power up your USB Drive.
After making sure about this, power up your system,
and plug the harddrive, then Right-Click on my
computer icon, select manage, then go to Disk
Management Option.
On the Disk management option Page you should
see ALL the drives installed on your system,
including the hidden ones, so what you will just do is,
try and locate the one representing your harddrive,
and right click on it. then select "Change Drive letter
and Paths", and give the drive any new, unique letter
(i.e alphabet) different from the ones already on your
system, and click on OK.
This should make your harddrive to be detected
automatically.
Try this out and let me know how it goes.
Hope this helps you out.
Jan 02, 2010 | LaCie d2 Extreme (300790U) 250 GB Hard...
COMPUTER NO LONGER RECOGNIZES IT. WHAT IS THE EXTERNAL DC VOLTAGE ? BUSLINK 3 1/2 FLOPPY EXTERNAL DRIVE FDD1 SER.# 1Q3B O6281 PC SAYS DRIVERS ARE OK
I recommend that you upgrade to a newer technology. The flash drives and other usb CD/DVD drives are newer and "plug and play" without much hassles. ....besides they carry more in terms of storage. Slightly more expensive, but less trouble.
Kind Regards
Sep 13, 2009 | BUSlink (FDD-1) External Floppy Drive
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computer does not recongnize connection
External is damanged or you have problem with USB drivers...
May 10, 2009 | Beyond Micro MobileDisk 500GB 3.5 External...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Buslink UII-250 not recognized any longer after fall
i suggest that your hard drive is comatose, from a severe office concussion. Take it to the emergency computer service dude nearby, and hope, cross your fingers, that the data is recoverable.
Mar 16, 2008 | BUSlink UII-250 250GB External USB 2.0...
Computers & Internet Logo
640 people viewed this question
David Payne
David Payne
