Sorry, there are NO Visioneer drivers available for your scanner. Unfortunately, that model was one too soon for them to develop the drivers since it's been discontinued a while back.
However, within Vista Support, there are ways to install the scanner and while you may lose some functionality, you should be able to scan, at the very least, pictures -- IF Vista has 'generic' Visioneer-type drivers within it database. (Meaning, when you plugged it in to the computer and turned it on, did it find the scanner, but not the EXACT model? If it found A scanner, I'd let it install those drivers to see if you can get it to scan, etc. through the Photo Gallery, etc.)
IF you're successful with Vista recognizing the scanner, you would go through Vista's Window's Photo Gallery and/or Window's Fax and Scan -- as well as downloading 3rd party OCR software (like AbbyReader) and/or TWAIN drivers that are compatible (another whole level of "technical"!)
If none of the above works you may want to replace the scanner with one that's supported.
Good Luck!
Maggie B
