Canon MF 3200 Series
Telephone rings once and then fax kicks in. What setting am I missing.
Mode is Fax/Tel
External Phone is connected.
Ring Start time 8 sec
F/T Ring Time 10 sec.
Not sure what Ring Start time and F/T Ring time does...these were defaults.
  • Anonymous Dec 01, 2008
    installation driver
    President:
  • 2,072 Answers
There should be a setting, most likely under advanced fax settings that is called Rings To Answer. That normally can be adjusted from one to seven rings.
Posted on Feb 25, 2008
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a Model MF 4150 , Serial No. JVM 73593 The Basic Guide that came with the purchase does not provide the necessary information. I have a phone on the same line as the fax machine (plugged into...
I'm going out on a limb here, and guessing it's a Canon imageClass MF4150... If not, please disregard this solution.
The advanced manual can be viewed / downloaded / printed here, directly from Canon:
http://gdlp01.c-wss.com/gds/0900006459/imageCLASS_MF4150_Advanced_Guide_EN.pdf
To stop it from interfering with the telephone conversation:
Issue: Fax interrupts telephone conversations in answering machine mode (AnsMode)
Solution: Setting the Receive Mode - ICMF 4150
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine.
    If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Apr 25, 2008 | Office Equipment & Supplies
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
FAX DOESNT RING WHEN RECEIVEING CANON FAX-L350
These units only ring under two circumstances. First the external phone must be attached. It has a volume slider on the phone. Second. The recieve mode must be st for Fax/Tel not anything else
Jun 20, 2009 | Canon FAX-L350 Plain Paper Laser
How to manually receive fax from canon mf 3200
If it runs thru a phone line- pickup the phone and hit start button - if not just hit start when you hear it ring
May 24, 2009 | Office Equipment & Supplies
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
1,766 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
