Question about SMC Barricade g SMC2804WBRP-G Wireless Router
My laptop cannot locate my network
I have a desktop and laptop connected to an SMC8014W-G. After being online this morning with no problems, the laptop can no longer find my wireless signal. Although my desktop (which is connected to the router with an ethernet cable) connects without a problem the wireless connection is gone. I am getting a message that the network cable is unplugged approximately every 5 seconds. In my network connections window the network status goes from "connected" to "network cable unplugged" every 5 seconds. I've checked and re-checked the cable, I've power cycled the router, I've restarted both the computers. The WLAN led and the LAN port led also go out every 5 seconds and then turn back on. I'm not very knowlegdable with this stuff so I've now tried everything I can think of.
Any suggestions?
Robb
  • Robb0921 Mar 24, 2008
    I'm an idiot. Simply interference from my wireless phone base in the same room!!!!!!!
Have you tried MAC filtering to remedy your problem?
Posted on Mar 24, 2008
I can not open my labtop on my wireless, it ask me for my password, I give it and it tells me it is the wrong one. I have 2 computers on it with know problems..
Posted on Feb 25, 2008
Can I hook my wifi laptop to my desktop and get online?
Hi there, you may be able to connect them together using an ethernet cable. When you do this you may need to bridge the connections to make them work. Once you have the ethernet cable connected go into network and sharing centre, then into change adapter settings. Hold the ctrl button and click (once) both of the adapter icons, then right click and select "Bridge Connections" This should sort your problem. (I am assuming that you are running windows machines)
I hope this helps.
Jun 02, 2015 | Computers & Internet
SMC8014W-G Can't find username and password to find network key. Default gateway is 192.168.0.1
Hi chris,
For you to access the Wireless Setting Page of the Router. Open a browser then type 192.168.0.1 on the address bar. The Default username is cusadmin and the password is password. If this doesnt work you can reset the router to its factory state by pressing the reset button at the back of the router for 15-30 seconds using a Pen or Paper Clip. You can also refer to this manual of SMC8014W-G.
Thanks for using Fixya.
Feb 03, 2011 | SMC Barricade g SMCWBR14-G (662698582192)...
I don't have wireless internet access. I have internet on my desktop computer with my Linksys WRT110 router connected. I lost connection this morning while online. The network doesn't show up on the...
Turn the router off.
Count to thirteen.
Turn the router on.
In Windows, click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Try again to access the Internet.
Sep 30, 2010 | Linksys RangePlus Wireless Router WRT110 -...
Wireless Printer Issue.
As I understand your issue, the HP Laserjet 1020 is a USB printer. You have it attached to a desktop PC. If that PC is rebooted, you can print for a short while.
The problem is probably not your network, but your desktop.
I would do the routine maintenance on it. Clear all the temp files, check hard drive free space and defrag the drive.
Then get online and download Malwarebytes.org spyware malware scanner tool. Scan the desktop PC for malware and clear out anything that may be occupying the resources of this PC.
Apr 06, 2010 | Nortel 2332 802.11a/b/g Wireless Access...
I can only connect to router with ethernet cable and not wirelessly on one laptop and a PC but can with another laptop
If i have understood u correctly u have 2 laptops n 1 desktop.1 laptop going online.desktop and other laptop not connecting.As u r able to connect laptop wirelessly to ur router,u have configured ur router ie created a wireless n/w with network name and password(if its secured connection).You are not able to connect may be bcos u have not scan for the network in your desktop and other laptop so scan and connect to the network .If u want me to guide through scanning steps im ready to help u.
Sep 24, 2009 | NetGear DG834G Router
My router is hooked up correctly on my desktop and my laptop shows it is connected with a strong signal, but I still cannot get online, any suggestions
If you can't get online on either machine, plug your ethernet cable directly from your cable or dsl modem into your desktop. If it shows a network connection and you still can't get online, it may be a service provider problem. I am assuming that your service provider did not ship you a router, only a modem. Hooking up 2 routers on the same connection can be very tricky.
Jul 30, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Setting up and configuring networks
The main problem on your setup is your router. This BEFSR41 doesn't have wi-fi or wireless capability. You can only go online on your laptop if you connect it hardwired to the router just like your desktop. You must purchase a wireless router if you want your laptop to work wirelessly
May 09, 2009 | Linksys BEFSR41 Cable/DSL Router with 4...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Staying connected to the internet
if you are up to it you might wont to swith to verizon Fios they have same things like chart that includes internet, tv, and phone. There modems are easy to set up all you have to do on there modem is enter the ip adress enter the defalt user name and password and change it to one you can remember and you would be online. One other thing most of there routers have built in wirless network asses which is protected by a WEP password which is located on the botom of the router.
To check if you qualify go to www.verizon.com and lock for there to enternet choces you wold need to enter you home phone # or adress to see if it is avaliabe.
i hope this would help.
Dec 31, 2008 | Sony VAIO VGN-FJ290P1 Notebook
Ip config is not finding my ip address?
No IP address? most likely the network is diable or the network card drive is deleted.
right click on the network icon>>porperties. if you see a network icon then right click on it and enable the network, if not, then the network driver is deleted.
go to control panel>>system>>hardware device, and see if there is a (red X) on the nework card.
go to the vendors website and download the network driver.
good to go!!!!!!!!
Dec 12, 2008 | E-Machines eMachines Desktop PC
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
313 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
