Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
Posted on Feb 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PHILLIPS TV TUNER CARD INSTALLED CANNOT BE DETECTED
I INSTALLED A PHILLIPS TV TUNER CARD ON MY COMPUTER BUT CANNOT BE DETECTED. WHEN I TRIED TO REINSTALL DRIVERS FROM AUTOMATIC SEARCH, REMARKS NO DRIVERS INSTALLED
  • GAGAY Feb 25, 2008
    wish to experience help from experts for future references. i am a freshman in computer hardwares/software troubleshooting at home.
  • mahima joshi Jul 01, 2008
    my tv tuner card works on xp but not on vista.ihave installed latest driver also.pse help.
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Feb 25, 2008
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328498
Points
1751
Depending on OS, only the hardware will be detected. Your drivers should have been installed from the disc you have to install....accordianman
I have installed Window 7 Ultimate on my computer, and i have a Tv tuner card Philips SAA7130 but i don't have software to watch tv. i have installed drivers and my computer recognized it but i still need...
Greetings looking for software drivers for your Phillips Windows 7 tech support team seems to think if you install the tuner that Windows Update will install the driver it also could be had at the optional update section of Windows Update. You can also go to the manufactures site and see if they have the software there under downloads usually under the support links. Click Here thanks for using Fixya! please post a vote for me if this assisted you in any way have a wonderful day. John
9helpful
I need a driver for a FM1236/F H-3 SV21 Phillips TV tuner card
Hello provmobile,
Please check this out,
http://www.bioticaindia.com/fm1236.html
Hope this helps.
8helpful
Phillips SAA7130HL TV Tuner VISTA 64 BIT DRIVERS
well i had the same prob, so i downloaded drivermax, which I think is free.
drivermax scanned my computer and found all the drivers I needed including the vista philps tv tuner driver.
another way is to download iobit advanced system care which is an excellent free program and click the utilities button and then click drivers update. This should give you the philips driver as well.
hope this helps
it certainly worked for me
anyway you should be able to use the 32bit xp driver.
regards peter
Zebronics tv tuner 2007 model.
the driver is not working proper thats y remove & reistall ur driver
1helpful
2answers
Driver problems with OEM 7130AA WDM Video Capture device (Phillips chipset)
Hi.
Use this to update your drivers
http://rapidshare.com/files/149632922/Driver_Scanner.rar
Hope this helps.
Regards
Faraz
60helpful
11answers
Phillips tv
Are you connected using R,G,B (component) cables? Check them to make sure they are in firmly - if so, then try a new set - that may very well fix the rolling issue. (Unless the rolling is caused by poor antenna reception).
Press "Sleep" on the original remote control for this TV if you still have it until the TV says "Sleep OFF".
If no strong TV signal is detected, this unit goes into sleep mode, which may explain Tuner B shutting off after 5 minutes.
2helpful
Driver required for SAA7130 TV card
have you tried the manafactures website if not have you tried calling them
Dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
