Question about Sony RDR-VX530 DVD Recorder/VCR
Remote doesn't work
Dvd is stopped on mode 1/dvd 1/cant change because my remote doesnt work
  • 2 more comments
  • oronoque Feb 27, 2008
    Thanks for your help but the remote works as it can increase volume and when screen is on, whatever I touch on the remote changes the screen to dvd1.
    Stan
  • oronoque Feb 29, 2008
    any more suggestions?
  • oronoque Mar 20, 2008
    Solution 2 & 3 were helpful.
    Actually Solution#3 was the BOMB .Worked like a charm after doing this.
    THANK YOU
  • drgeorge454 Nov 02, 2008
    remote will not work the player is fixed in DVD 1 mode
Both remote and the main unit has a default command mode. and that is command mode 3. if you may have accidentally browsed thru the menu of the dvd/vcr recorder and set the command mode to 1 , that may have caused teh issue. Solution: if you have the supplied remote rmtd224a, just slide the bottom front cover lid. There is a small white sticker on the right bottom corner that you can peel out and you can see mode 1 2 3. slide the switch to the appropriate command mode setting of dvd. Ex: if remote is not working then the unit displays DVD1 when pressing a button, the command mode setting of your dvd player is command mode 1 and thus the switch on the remote should be on mode 1. This should surely help you.
Posted on Mar 14, 2008
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Posted on Mar 13, 2008
  • Andy Castro
    Andy Castro Oct 16, 2011
    Gosh!! I finally got it. Thank you very much, I was determined to get this fixed. The other ways just didn't work for me. Under the white sticker, I found the way. D1 D2 D3, wow!!
    I did it!!!! Thanks...
Okay this took all day to figure out because I too was stuck in "DVD1" and the remote wouldn't work and there are no controls on the unit itself and don't even get me started on the manual. (Why I didn't start at the back of the book and work forward... I should know it's always on the next to last page!)
Anyway, did you know the "bottom" half of the remote control slides down to reveal other keys? I didn't, but once you "slide" it down at the very bottom right hand corner is a "Command Control Slide" move it over to DVD1 hit "System Menu" and go to settings and reset it to dvd3. (If you want....)
Good Luck!
Posted on Oct 07, 2008
  • shebebad Oct 07, 2008
    BTW - The reason your remote only worked to control the volume has to do with the TV set. It probably would also turn off the TV set, but won't do anything else if it can't communicate with the DVD. Read the above and move the command mode to DVD1.
Hold down enter key then the number 1 key at the same time for at least 3 seconds, Now your remote is also set to DVD1 and you can now turn off the recorder. Turn the recorder back on and hit menu and change the recorder back to DVD3 and change your remote back to DVD3 by holding down the enter key then the number 3 key for at least 3 seconds.
Posted on Jun 16, 2008
  • 76 Answers
The batteries are dead and if they arn't you need to go get a new remote. sorry. Hope this helped =)
Posted on Feb 25, 2008
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Jul 19, 2009 | Panasonic Televison & Video
Sony vx-515 - I put it on DVD-1 using the remote and cannot chang
Remote control has mode select switch, set it on DVD-1 to control Recorder with remote.
Jun 11, 2009 | Sony RDR-VX515 DVD Recorder/VCR
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Cant get rear entertainment system to work- 05 durango
You need to change the mode on the stereo to dvd. The dvd sound comes through the vehile stereo. I just bought a used one a week ago and had the same problem, eventually figured it out.
Dec 16, 2008 | 2005 Dodge Durango
Will not reset to the easy menu as to change DVD 1 setting
Try putting fresh batteries in the remote and then:
1. Push and hold "Enter"
While
2. Push and hold "1"
Keep them down for about 5 sec.
Your remote is now in mode 1 and will talk to your RDR VX-525.
In the EZ Setup are you can change the unit back to remote command mode 3 if you wish. The remote will stop working again, but you just have to repeat the setps above using button "3" instead of "1".
Aug 17, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Sony RDR-VX530 DVD Recorder/VCR Logo
427 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
