I have a 92 accord. I was on the highway doing about 65-70 and the car randomly shifted into 3rd gear and the RPM's shot way up. I got it back into fourth the car ran fine. I went to ge tin my car today and put it into D4 and the car doesnt move.. Put it into D3 nothing.... Samething all the way down the line D2 and D1. someitmes if i put it into D1 i can ge *** going but if i hit the gas to much it will just rev up... What could the problem be? the car has bee shifting very hard for about 5 year before this.
It is either your Vehicle Speed Sensor (easy to change) or your Automatic Transmission Computer (capacitors burn out on these boards,
there is a fix for this too, the picture is at the bottom of this
page). You need to diagnose by removing the lower right plastic kick
panel on the passenger side. There you will find a blue plug. With the
car OFF stick a paper
clip, wire or stuff the plug with foil to make electrical connection so
that the two terminals are touching. Then, turn the ignition to ON (not
enough to start it though, just power it up). When you do this, count
the blinks in the "D Light" or count your blinking Check Engine Light.
Both are different but can refer to different things wrong with your
car. A long blink is the first number and the short blinks that follow
are the second number.
So imagine this as being 14 : ___ _ _ _ _
Below is a decoding chart:
The first section will be the check engine light codes, the next one is the Transmission Control Unit Codes read from the D Light;
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
TCU Codes:
CODE LIST:
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
