Question about Kenwood KDC-MP205 CD Player
E-99 and other times time TOC ERROR shows up.
I bought my KDC-MP205 less than a year ago. I was playing and MP3/WMA disc and an E99 showed up. I then took the cd out and put it back in and a TOC ERROR showed its face. The tuner and AUX work, but the cd function does nothing no matter what format disc i put in.
  • mustypines Feb 27, 2008
    Hey thanks for the advice, though it only partially fixed the problem. The disc got it to start reading audio cd's, but it stil wont read a data cd.
  • bluesman153 Feb 28, 2008
    Tocc error and overheating in Kenwood kdc-mp205. Have disks playing fine and then all the sudden I get a tocc error. Also find some disks spin very fast (trying to read the data?) and when I eject them, they are very warm. I only play mp3 format so my only question is could it be related to the bit rate of the file? Is there a limited amount of ram in the deck that is used up by high bit rate mp3 disks?
  • 199 Answers
Hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
I got message "e99" in my 10-disc changer kenwood kdc-c719, what does it mean? ty
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Unfortunately the E99 code is not definitive. There may be a mechanical jam with the changer or a problem with the motor.
Dec 25, 2014 | Kenwood KDC-C719 10-Disc CD Changer
I HAVE KENWOOD 10 CD CHANGER, DISPLAYING E99
I have a 10 cd changer and it shows E99 what can I do to eliminate this problem . thank you
Feb 05, 2013 | Kenwood KDC-C467FM 6-Disc CD Changer
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
I get the TOC Error, when I put bought cds in.
don't think you will like this answer but, it probably time to get a new cd player... you could try using a cd cleaner designed to clean the laser or spray the insides with compressed air.
Apr 29, 2010 | Kenwood KDC-MP228 CD Player
Toc error
TOC is short for "table of contents". It tells the memory what is on the disc and where...... Does this do this on all cd's?? If so, the disc drive motor is probably at fault. If it's one or two discs, it's probably a scratched or smudge near the center of the disc. CD's play from the inside out.....they start with the TOC.
Sep 13, 2009 | Kenwood KDC-MP332 CD Player
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP205 CD Player Logo
823 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
