My GE chest freezer quit working. When I plug it in, something runs for about three seconds and then shuts off. It does this over and over again - on for about 3 seconds and off for about 10 seconds.
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
This sounds like a bad overload relay or locked up compressor. If you are very technical, you can do some troubleshooting by checking to see if the compressor pulls "locked rotor" amps when it tries to start. This information should be on the unit nameplate and will be listed under "LRA". This requires special testing equipment (an amprobe). Also check for any bad connections at the plug and the terminals where the cord terminates inside the electrical compartment on the freezer.
Something else to try is to plug the freezer into a different electrical outlet and see if the same problem occurs.
If the freezer is over 15 years old and the compressor is bad, it will not be worth the cost of repairs.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
