Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Throttle problems throttle cutting out at half throttle
  • Anonymous Dec 02, 2008
    I have a 2003 harley deuce and it will not accelerate past 70 mph. At half or 3/4 throttle it acts as if it has a govener and has no power!
  • dink2u May 11, 2010
    What kind of bike? Miles etc?
Check the spark. sounds like coil or points breaking down
Posted on Mar 21, 2008
I have a 2009 Yamaha rhino 700 cutting out at half throttle and popping cuts out at 35 mph
Cutting out at 32mph - Yamaha Rhino Forum - Rhino Forums.net
www.rhinoforums.net > ... > Members > Forum Help, Questions and Info
Apr 23, 2011 - 12 posts - ‎8 authors Once it cuts out I let off the gas to let the speed drop a little, it pulls fine then ... The reason I say that is because feathering the throttle gets you 4 mph more .... Spent halfa night starting it and reving it trying to go somewhere but I'd give it ... Join Date: Sep2009 ... 2008 yamaha rhino 700 cuts out at 40 mph. 700 Sputtering with constant throttle
Jul 18, 2012
Rhino missing/dying/backfiring when running on top ...
Aug 12, 2011
2009 Rhino 700 Crank No Start
Dec 12, 2010
full throttle
Aug 31, 2009
More results from www.rhinoforums.net
Sep 27, 2015 | Yamaha Motorcycles
Throttle
Since 2008, Touring models have an electronic throttle (Throttle By Wire) instead of traditional cable(s).
Also, you might have a "Parade Mode" on your bike, where the rear cylinder cuts out at high temperatures/low speeds (such as being in a parade).
Pull your DTCs (Diagnostic Trouble Codes) and post here and I'll look them up.
Jun 18, 2013 | 2009 Harley Davidson FLHX Street Glide
17.5 hp ovh Briggs and Stratton engine hesitates after about a half hour of cutting grass then wants to shut down and what i did to prevent it from shutting down was play with the throttle and gradual
Could be dirt or water in the carb or perhaps something floating around in the exhaust.
Might be a blocked or almost blocked fuel tank vent...
Oct 09, 2017 | Measuring Tools & Sensors
Tiller engine after getting warm stops. I have changed the spark plug, cleaned the carb and replace fuel but still hav the same problem. It always fires back up and is good at the idle but when at full...
check for a full fuel flow to the carby
indicates a low fuel level possibly float level
check that there is a heat insulation block between the head and the carby
maybe head heat is tending to boil off the carby fuel if too low a level
Dec 18, 2017 | Honda 25cc 4-cycle Mini Tiller
Honda civic type r 07 wen i am half clutching coming to a stop i have no throttle is that anything to do with clutch switch
hi
no it a ecu problem it is cutting off you throttle because the ecu thinks you have stalled.
thanks
Dec 06, 2009 | 2009 Jeep Wrangler
2005 450r dies at full throttle
Sounds like dirt in the main jet of the carb. Take the slide out and clean the needle. The pull the float bowl and blow air or carb cleaner through the brass jet in the middle of the barb, where the needle seats.
Jul 01, 2009 | 2005 Honda CRF 450 R
Lands Phones Logo
44 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
