Question about Car Audio & Video
Earthquake PH150.2 4chnl amp???
I bought a used Jeep and this amp came with it. Is it any good? It looks a little older, works great but cant find any info on it? Know anything about it?
  • Brail Feb 25, 2008
    i have a 1800 watt power acoustk amps in my car and it has been working great. when i unhooked it to clean my car out and put it back in it didn't work. i put new fuses checked my hot and ground wire to see if it was hooked up and looked to see if i burned something inside the amp, everything good but nothings happing.
    Genius:
  • 1,066 Answers
You look for a dedicated fuse in the engine compartment? No shorts at all, speaker leads, ect, hook up the remote power lead form your reciever?
Posted on Mar 01, 2008
Since i have been using this Rimmel eye liner pencil my eyes have been extremely sore, watery and stinging like mad, sometimes it is so bad that I cannot open my eyes. is it possible to be allergic to this...
Yes it is very possible it could be an allergic reaction, amongst other things. First, where are you applying the liner exactly? It's very easy to accidentally apply liner to whats actually your inner lid and not even know it, that can be not only irritating but harmful as well. Second, are you removing your eye makeup before going to bed? That makes a huge difference! * If you don't feel like washing your face or don't have makeup remover handy another great method is a little bit of vaseilne on a cotton ball rubbed gently over the eye area, works GREAT and is cheap too. Lastly, do you wear contacts and/or have light colored eyes? Blue, grey & green eyes can be particularly sensitive even if you don't have sensitive or fair skin.
My suggestion to you would be if you're going to use eyeliner look for whats called a "Kohl liner pencil", the actual liner part of these pencils is really soft almost creamy but still in a pencil form. It glides on really well & pigmented with just a dab or a swipe on the OUTER rim of your eye so there's really no chance of it coming in contact with your eyeball. The older pencils that literally feel like pencils are no good in your case. I myself haven't gone a single day without my black liner since I was about 13 lol & I have very light blue eyes. I attached a link at the very bottom of my "CANT live without liner product", sounds like it might be perfect for you too.. and it stays put all day which is great. Though you may want to go a few days to a week with nothing on your eyes at all first and let them recover & breath if they're as bad as you described.
good luck!
Mar 05, 2011 | Rimmel Special Eyes Precision Eye Liner...
What would be a good amp to power my earthquakes tremor xr12 i have xplod xm2100gtx running to it right now but when a turn the volume up it doesnt hit very hard.hepl please....
try to find some thing with in its rms is the rule of thumb try looking around ebay i just picked up two A2300HCX great place to find car audio Hope this helps............
May 10, 2010 | Earthquake Sound TREMOR XR12 Car Subwoofer
Fuse for power cable on earthquake PH D2
I would go with a 40 or 60 amp fuse, this should be ok, you will hardly every run the amp to full capacity so its better to be safe than sorry.
Dec 02, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Dont have a problem just to say that my samsung portable 14inch tv still works a dream since i bought it in 1982.
Glad to hear it, older portables are usually good reliable televisions. I've had a Sanyo portable (it's in black & white since) 1974 & although I haven't used it for a while the last time I did it was still working great. If only every piece of modern technology were as reliable.
Jul 18, 2009 | Samsung Televison & Video
'Rear brake failure' flashing on the screen, yet the brake & indicator lights are working.
rear brake failure means something to do with the brake system not the lights
Jun 02, 2009 | 1996 Jeep Grand Cherokee
My Earthquake Supernova MK-IV 12 stopped working
kindly check out maybe the fuse was already explode...check the connections specially the coil of the speaker using a multi tester....thanksss and gud luck
Nov 28, 2008 | Earthquake Sound MKIV-12 Subwoofer
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
