Toshiba SD3980 is displaying "incorrect disk"
  • 76 Answers
It usually means that you either have the disk in upside down or its rejecting the disk for a number of reasons such as the disk is scratched or it has something stuck to the bottom. Hope this helped.=)
Posted on Feb 25, 2008
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
My computer will not back up files to a CD When I try the response is "D:/ is not available incorrect function" I was rold that I could come to this web-site and download a "disc...
Who makes this disk creator program?
One thing you want to do is check the properties on you CD drive in My computer and see if cd recording it enabled.
Jul 16, 2008 | Toshiba Computers & Internet
Cannot read dvds. Display says incorrect disk
If the dvd player is doing this on all disks then there is something wrong with the laser assembly. Cost to repair for what it is, is prohibitive. If tv has audio video input, connect external player to that for viewing disks OR buy another combo.
Aug 31, 2015 | Toshiba MD13N3 13 in. TV/DVD Combo
My sd3980 dvd player wont turn on
Some new dvd/vcr combo (or just dvd players) NEED to be plugged through either the HDMI or component cables (blue/green/red cables) in order to view the DVDs.
Try one of those to see if it fixes your problem.
P.S. don't forget to change the input of your TV to either the connection you are using for the DVD (HDMI or components)
Mar 19, 2011 | Toshiba SD-3980 DVD Player
The dvd player says "incorrect
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
Feb 20, 2011 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
I have a toshiba a105s4084 laptop when i use the recovery disk i get an error missage "WRONG MACHINE!" also have had error message NTLDR missing also error: 10e7160017 email ka4sji@juno.com...
You have a serious error on the hard disk caused by incorrect registry entries.
The recovery disk is obviously from a different machine.
If you at the start of booting press F8, hopefully you will get the menu inviting you to recover your system. If you don't, the recovery file is corrupt or missing and you will have to purchase a new OS.
It is probably too late to check for viruses but worth a go with Norton.
Dec 30, 2010 | Toshiba Satellite A105-S4084 Notebook
Toshiba DVD player SD3980 Keep getting an incorrect disc or bad message. Have turned it off & tried other discs.
check spindle motor,flexible wire, if this two is ok then your laser is at fault, note; be aware on installing flexible wire if its incorrect it may impair the operation of sled motor , clean clogs and dirts on sled gears
Oct 13, 2009 | Toshiba SD-3980 DVD Player
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
