Hose overflow My washing machine is overflowing from the hose in back as it drains into my home plumbing system. Is this a washer problem or a plumbing problem??
    New Friend:
Sounds like u need to tightin ur hose clap
Posted on Feb 26, 2013
  • 156 Answers
Its plumbing problem your stand pipe that the hose goes in needs to be unpluged
Posted on Feb 25, 2008
My Kenmore He Model 11028002012 backs-up intermittently. Not every wash but if I wash two loads back-to-back the drain overflows.
The drain overflows? If it is coming up out of the standpipe that the washer drain hose is hooked into, its not a washer issue, it is a clogged/slow house-hold drain issue. I suggest a plumber in that case.
Sep 17, 2017 | Kenmore Washing Machines
My washing machine keeps filling with water
If the washer keeps filling up without overflowing onto the floor , then you have the drain hose too deep into the drain and it is siphoning, pull the drain hose back up from being so deep and have it only about 10 inches into the drain, tie it into place with a shoestring or wire tie.
Now if your problem is that the washer is overflowing onto the floor, then there is a clear rubber hose that has been disconnected from the washer, this is the diaphragm hose. Have a technician reattach it. It shuts the water off and starts the machine when its gets enough water, but it wont if the hose is disconnected. Mr Burk
Feb 15, 2015 | Washing Machines
We have snked the drain line and put the water hose through the line and when we run the washing machine with no clothes in it the drain works fine. when we run the washing machine with clothes in it the...
Newer machines will eject the water so fast that older home plumbing may be too small to keep it from overflowing. We had no choice but to pay a plumber to install a larger drain to use the new HE washer I bought to replace my old one when the transmission went out. Then I had to fix the drywall after he ran new PVC to the larger drain further down the wall. I suggest asking how big of a hole they are going to make, and being prepared to fix that too.
Aug 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased an LG Front Load washer (Model WM2140CW). Best buy installed it. When I went to use it today, the floor flooded. Water was gushing out of the drain pipe (backing up). The LG drain hose...
You may have a drain line restriction causing it to back up. Pull the drain hose up about 6 inches and try it again. If it does overflow again, you will need to call a plumber to clear the drain line out in your plumbing.
Jun 16, 2011 | LG WM2140CW Washer
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't drain
remove the water pump hose and clean both the hose and the pump out-mike
Jul 29, 2009 | Tecnik TKL9260 Front Load Washer
When draining water overflows out of drain in wall?
Pick up a drain auger at your local hardware store or plumbing supply house. A general-purpose hand-operated one isn't expensive. Run it down the drain and it should clear out the clog that is causing the backup. It's likely just lint that's builtup, unless someone is missing a sock.
Jun 02, 2009 | Tecnik TKL9260 Front Load Washer
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
