Question about Canon Pixma MP500 All-In-One InkJet Printer
Printing in stripes
Help! My printer will only print in horizontal stripes of about 1cm. For example, it'll print 1cm all the way across, then 1cm will be blank, and 1cm will print, and so forth all the way down the page. This problem started when I changed the size 8 cartridges (all of them) because they were low or out. Usually I print in black and white from my larger 5 tank, but it's doing the stripes from that tank and all the other tanks. (ie greyscale or color)
I've tried cleaning the heads, deep cleaning the heads, aligning the heads, manually aligning them, uninstalling and reinstalling the driver, and so far nothing has worked.
On a side note (which is probably completely related) my black 8 ink tank sometimes isn't recognized. I've read that a lot of people are having that problem, and so far there's nothing to be done to fix it. It only does it some of the time. Usually if I take it out and put it back in, there's no problem other than it still prints in stripes.
  • Domina Feb 27, 2008
    Mine is also only printing a small stripe at the top of the page. Then it spits out the page, feeds a new one, and does it again. My stripe, however, is only black. In order to make it stop, I have to cancel all print jobs, turn off the printer, wait, turn it back on, and re-send the print jobs.
  • esketo Nov 08, 2008
    My Epson stylus color 980 has the same problems, one stripe ok and another in blanck.
    What can i do??
    Is fixeable?
    Thanks
    Top Expert:
  • Canon Master
  • 26,708 Answers
Possibly time to replace the printer.
Posted on Mar 07, 2017
SOURCE: Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
Posted on Aug 04, 2008
SOURCE: mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Posted on Mar 05, 2009
SOURCE: Canon Pixma ip3000 printer, changed black ink
i had the same problem and just repeated the cleaning and testing, eventually the black showed up but took more than a few repetitions
Posted on Jun 30, 2009
  • 97 Answers
SOURCE: i455 printing totally blank pages
Don't know that particular model but try this.
Sounds like the lines are a bit plugged and are running dry again after the script page.
Never leave an inkjet or deskjet for more than a week or so without using it because the ink wells can dry up.
Take a Q-tip and dip it in alcohol.
Remove the cartridges and soak each hole with a brand new Q-tip.
Let it dry.
You may have to do this a few times before you get results.
Now put in the cartridges.
Go to
Start
Control Panel
printers
Click on your printer
Go to Properties
Go to Maintenace
There should be some kind of thing in there that will allow you to clean and deep clean your cartridges.
I have recovered many "seemingly hopeless" printers this way. A lot of printers that can be rescued end up in e-waste, wasting a lot of money.
Look in the yellow pages and find you local dealer if all else fails. These people are often quite helpful.
Posted on Sep 25, 2009
  • 352 Answers
SOURCE: Canon MX300 printer--I replaced the
Try this method to get the ink flowing:
  1. Simply fill a saucer with approx 2mm of just boiled water
  2. Place the print head in the saucer with the head in the water.
  3. Leave the head in the water for approx 2 - 5 Mins
  4. The Heat will assist in dissolving any blockages and help the ink to flow with out using any chemicals.
If it is a compatible cartridge you have used then it is possible to get a failure. Most are re-manufactured and are not 100% Reliable.
Also make sure the contacts on the inside of the printer are clean and all there. sometimes they can be damaged by removing and replacing cartridges. these can be cleaned with alcohol wipes.
I hope this helps Regards GM
Posted on Apr 23, 2011
Stripes in printing pictures in canon ip2700
Run the utility maintenance printer coming with the printer , for to clean the head from your printer.
God bless you
Jul 28, 2013 | Canon iP2700 Inkjet Photo Printer
I have just replaced my cartridges and the printer is now printing with a four blue horizontal stripes across each A4 page (each about 1cm wide). Please can you help.
sounds to me like the cyan toner cartridge is defective, if you still have the old one, put it back in and see if the lines disappear. Get Paid
Jul 28, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Printer prints every other horizontal strip
hmm..check here for fresh printer drivers just as starting point..
Mar 06, 2008 | HP DeskJet 920c InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
2,816 people viewed this question
old marine
old marine
