Fuji FinePix A345 Digital Camera Logo
Posted on Feb 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card how can I get a new memory card?
Anonymous
Level 3:
  • Master 667 Answers
  • Posted on Feb 25, 2008
Anonymous
Master
Level 3:
Answers
667
Questions
0
Helped
221722
Points
1593
The XD memory cards can be found online on sites like eBay or at most larger retail stores like Best Buy and camera retailers
I have a brand new camera. I placed a brand new memory card in it and was able to take 3 pictures when a message came up that said out of memory.
Likely the issue is the pictures are going to internal memory.. There should be a menu selection to transfer to memory card. AND a setting to USE memory card / assuming it has already been formatted for your camera (usually 1st step required when inserting a new memory card )
ELSE you have a faulty memory card...
OR the camera is not registering the card.
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 • Cameras
2answers
My new 4g memory card will not let me use it, say memory error
Hi there!
Since this is a new memory card, the first thing that you can do is to format the memory card through the camera menu.
If that doesn't work, try another memory card. If that card doesn't show the error then your new memory card is the problem.
Hope this helps.
May 14, 2011 • Cameras
I can not get my games off my memory card to play on the new R4i card I bought for my DSi. What do I need to do?
You just have to put the memory card with your games in your computer, copy them to a temporary folder, then put your new memory card in and move them to the new memory card. Or if they are both R4s, you should be able to just put the memory card in the new unit.
1helpful
Memory Card locked
this solution is from a another website about card error... i dunno if this will help fix ur problem but i hope this will give u idea how to fix it... okay.. tell me if this works, coz a lot of people were encountering the same prob as u.. thank God i havent encounter this error...good luck..
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
credits: www.cardrecovery.com
Memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Solution:
59helpful
5answers
Change the default memory to the memory card in samsung s3310
I have bought new Samsung S3310 mobile. I want to ask that, how to change the default memory to memory card because when I transfer any file through bluetooth it pop ups that phone memory is full please delete something. My memory card is 1 GB.
Please help me to solve this problem
1helpful
My memory card has bad format should i get a new one
If you have a card reader try to format it via your pc that may help to recover your card. Else you have to purchase new one. Best of luck.
2helpful
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
2answers
Memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
