Question about Sharp AL-1642CS Copier
Metal grid came off
Dropping toner on paper & grime texture on paper
where does grid go are did it break off.
  • techiam Feb 28, 2008
    have not received drum unit yet
    I ask about main charge grid they did
    not know if it was on the drum unit
  • 168 Answers
It sounds like the Main Charge Grid. If you are able to take it out of your machine then the grid probably broke off.
Is the grid a thin shiny metal piece about 10" long by about 1/2" wide?
Does it have a bunch of lines/open spaces on it.
If this is what i am describing, then you can purchase another drum unit, and this should take care of your problem with the copy quality and you will not have to worry about the grid.
Just to be on the safe side, where ever you place your order for a new drum unit, ask the company if the Main Charge Corona and grid come with the unit. I am pretty sure that model does have everything all in one unit.
Good luck.
Hope this helps. Please remember to post a feedback and rating if I have helped you in anyway.
Mac =)
Posted on Feb 25, 2008
  • Mac Gyver Mar 04, 2008
    Just checking to see if you have received the new drum unit yet and if that took care of the problem.
Minolta EP4000 C0200
Hi Usha
The possible causes
-charge corona
-drum in end life
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Oct 14, 2015 | Office Equipment & Supplies
What could be the cause of a copy fading in the middle or a faded copy
Hi There, this depends on what make and model your machine is, in general, faded in the middle means that the charge roller or corona unit is dirty or the paper separation roller/grid, stop your machine while the paper is halfway through, then look at the toner image on the drum, if that is light also, then the problem is with charge roller/grid, if the image on the drum is nice and dark then the problem is with your image separation roller/grid.
Jan 13, 2015 | Office Equipment & Supplies
How to take out the thin line in my photocopy
If the line only happens when using the auto document feeder, clean the strip of glass to the right of the main table glass. If it is happening from both the document feeder and the table glass, you need to clean the main charge unit. Open the front door and remove the toner cartridge. There will be one blue screw holding the developing unit the toner cartridge slid out of. Remove the developing unit, and keep it level. Now open the side door and slide the drum unit out from the front of the machine. You will see the black plastic charge unit mounted to the top of the drum unit. Remove 2 screws and remove the charge unit. You will see a metal grid and underneath that a piece of metal with teeth running the length of the charge unit. Use a tooth brush and alcohol to clean the teeth and wipe the metal grid.
Jul 24, 2012 | Sharp AR-207 Copier
My rear defrost will not work but the light works, whats the problem
Visually inspect the heating grid attached to the inside of the rear window for breaks in the horizontal lines. Any break in the filaments in the grid will cause a partial failure of the defroster, leaving a portion of the window fogged or obscured.
  • 2 Use a test light or voltmeter to detect breaks in the filaments that aren't visible to the ***** eye. Touch one lead of the light or voltmeter to a grounded metal part of the car and the other lead to a spot on the heating grid. If the light doesn't light or the voltmeter doesn't register a reading, that indicates a break in the filament.
  • 3 Place a piece of tape on each side of the break. Align one piece just above the filament, the other piece just below it, leaving a thin space through which the filament passes.
  • 4 Apply the filament repair liquid with its applicator onto each break you've identified. Be sure to thoroughly cover the broken spot. Allow the repair to fully cure per the instructions on the bottle, then carefully remove the pieces of tape so they don't rip the filament repair.
  • 5 Inspect the the vertical lines on the heating grid if you've discovered that the entire heating grid fails to work. Any break in the vertical lines will cause complete grid failure. These can be can be repaired in the same way as the horizontal lines. Check to ensure that the metal power tabs on each side of the grid are securely fastened to the vertical lines, as a break here will also prevent the entire grid from heating.
  • 6 Reattach the metal power tabs to the heating grid as needed by removing the tab from its connector and repairing it using the epoxy found in the heating tab repair kit. Be sure to allow the full curing time indicated on the kit before reinserting the tab into the connector to ensure that the circuit isn't broken.
  • 7 Check the power switch and wiring to the rear window defogger if there are no breaks in the heating grid and both of the metal power tabs are securely connected to the grid. Replace the switch and/or wiring as necessary.
  • Oct 16, 2011 | 2000 Ford Taurus
    Code appears CO200. What does this mean
    C0200, charge corona failure.
    Hope this helps.
    Aug 12, 2011 | Minolta EP4000/5000 CS/PRO Copier
    Prints with lines to the right margin of the page. How can this be corrected?
    This can depend on if they are white or black lines and if you can feel a texture on the paper. Most often the cause is a bad toner cartridge. If you are using generic toner cartridges, I would suggest trying a new HP one instead to see if it clears up. If you feel a deep texture to it, the fusing unit may be wearing out and need to be replaced.
    Feb 03, 2011 | HP Laserjet P4015x Printer
    We are printing 2 sided agendas which contain 44 pages each. The print from the first side is showing through on the second side. How can we fix this problem?
    ia the paper you are using heavy or velum textured some papers with a textured surfaces are not compatible with copiers..the fuser section cannot heat the toner in the texture enough for it to adhere to page. check the same print job with normal paper and compare results..
    Aug 13, 2010 | Canon C3380i Color Copier
    We have a Sharp 1641CS copier will not feed or copy
    Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
    May 29, 2009 | Sharp AL-1641CS Copier
    I cleaned my air cleaner and now it will not turn back on
    When you cleaned your cleaner, you must be gentle with it. Wipe down with a lightly moist cloth or paper towel. make sure you dont shove any grime between the metal cleaning grid and the plastic holding it all together. that can cause lots of problems. Your air purifier probably wont start because of an auto shut off safety feature. Be sure that everything is in its proper place.... make sure hte front grill is fastened on correctly as well as the back grill. if those are not secured properly the unit will not start. also, check that your collection grid is placed all the way inside the unit and wait for the click noise that indicates that its locked in place. at that point the unit should turn on and you can once again enjoy fresh, pure air!
    Dec 09, 2008 | Sharper Image Hybrid GP (SI724) Air...
    Brothers HL 1240 Alarm light on
    Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
    Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
    If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
    If neither of those help, write back and let me know what lights stay on when the printer stops.
    Sep 06, 2008 | Brother HL 1240 Printer
    78 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
