Question about Canon PIXMA iP1800 InkJet Photo Printer
Printer error message
I purchased a Pixma IP1800 printer. I keep getting a "service error 5100" message. I have reloaded the paper, shut the printer off & turned it back on, checked connections ....
What do I do?
  • lalalandhkg Apr 11, 2008
    What do I do?
Service error 5100
Posted on Jun 28, 2009
We still cant get it to print!!!!!!~ what is the matter!!!!!
Posted on Feb 26, 2008
I been try to fix it for an hourssss,finally,i get it work!!!!!!
i use a soft hair brush to brush all the small gap n open the top then blow air to the machine.
n i made a mistake b4 by not push back the ink tank all the way to the end back to the right hand side.
hope it help for u guys as well.
Posted on Apr 11, 2008
My printer Canon PIXMA iP1800.with error 5100
Error 5100 is Cartridge Position Error. Try cleaning the whole strip where the cartridge is placed.
Jun 30, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
Printer wont print and comes up with service error 5100
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
My Pixma ip1980 service error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100
Try this to get rid of the error:
Service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Good Luck.
Jul 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon PIXMA iP1800 InkJet Photo Printer Logo
390 people viewed this question
old marine
old marine
