Magnavox DVD455 Player
The player shows "Nodisc" even though a disk is loaded in the tray. It appears the player attempts to spin the disk, but continues to indicate Nodisc after it shows "loading." Any ideas
  • 979 Answers
A read of the disc has failed for a list of possible reasons; dirty media, dirty optics, failed laser, alignment all come to mind. In short, it's time for a shop service...accordianman
Posted on Feb 25, 2008
DVD Player doesn't recognize disks present
Get a DVD cleaning kit and follow instructions, if this fails the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to buy.
May 08, 2012 | Yamaha DV-C6480 Multi-disc DVD Player
My dvd player keep on loading but it end up no
from direct experience, the problem is that the disk does not start spinning by itself - it will if you have the top off and give it a spin to start it ... I don't know what the ultimate solution is though.
Jul 04, 2010 | Pioneer DV-400V DVD Player
Put disc in player spins it, and says ERROR and
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say error and no disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | RCA RS2650 Shelf System
I have an RCA DVD/VHS combo with TVG. The DVD
This is a work-around rather than a solution. We put an audio CD in the tray and after closing the tray the unit begins to play the music. After waiting a few seconds we open the tray and quickly substitute a DVD and it loads OK. We had also tried cleaning the player to no avail. The CD approach is a pain but it does allow us to play DVDs. Jim
Jan 15, 2010 | RCA Televison & Video
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
Jun 06, 2008 | LGDVB418 DVD Player
Unlock codes
I have a Magnavox DVD player DP100MW8B, and I need to get the codes for unlock the region codes, can you help me?
Mar 29, 2008 | GoVideo VR3845 DVD Recorder/VCR
Can't get a disk to play
I've seen failure of the spindle motor to cause problems like this. Problem can also be a leaky diode in the power supply.
Nov 19, 2007 | Panasonic DVD-S35 DVD Player
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
