Question about Car Audio & Video
Car amp ( fusion fp-1002 powerplant ) is fried
I bought a fusion amp ( fp-1002 powerplant ) and 2 10 inch pioneer premier subs ( 350W RMS , 700W max each ) from my uncle for cheap , and i got them professionally installed at a local car electronics dealer , and about 5 hours later when i was listening to my music ( was testing settings out ) subs suddenly stoped ( i assumed it overheated so i gave it a few minutes ) , but the status light( red light ) on the amp stayed on and the subs only made small noises , my 6x9s were making more bass .... i went to the place where i got them installed at and they tested my amp connections and told me my amp was fried , but the two ( 30 ) fuses were still in mint ?? , i need to know if there is anyway to fix my amp without having to buy a new one
    Problem Solver:
  • 12 Answers
Blown capacitors. take to a friend or electronics repair that can replace with better capacitors. had same problem with an old comp 1200 amp. friend of mine replaced with better capacitors and wooohh mamma!
Posted on Feb 25, 2008
How do I make a sub box for my single ten inch re sx 10 inch sub dat is 1000 rms. Da box needs to be tuned to 35 hz
yeah, you likely cant build a box to tune 35hz... try just building a box that has correct spec by the manufacture for ideal operation, and adjust the gain accordingly, that's where you will attain your desired hertz, oh and by the way hertz refers to signal, and pulse rate,
Sep 12, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
Selecting an amplifier!
Buy a quality 2 channel amp. About 600 rms and set one channel as your highs using your crossover and then the second channel on "low" position for your sub. wire directly in to your low's channel with your sub at 2 ohms and then wire your speakers to the other channel.
May 23, 2010 | JBL GTO937 Car Speaker
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Car Audio & Video Logo
511 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
