Question about Canon EOS 400D / Rebel XTi Digital Camera
Alternative Charging Methods???
I have recently purchased the XTi from canon and I am wondering if there are any alternative charging methods to charge the removable battery? I used own the powershot G3, which had a removable battery pack also, so you could either remove the battery and use a wall outlet, or use the cable that came with it and charge the battery without removing it from the camera. Does the XTi have this capability/jack or am I out of luck??
thank
p3ter
    Problem Solver:
  • 6 Answers
Your out of luck. This method of charging is considered (nowadays) unprofessional. Thats why you rarely see manufactures such as Canon/Sony/Nikon (the big 3) use this - and company's like Kodak will. Yes, it is convenient, BUT, battery chargers are prone to go out. They work very hard, and get very hot, adding stress to other components. There is no such thing as a bullet proof charger. Many (quality) manufactures know this and avoid this added hassle. See, if the charger goes out then it's likely to disable the rest of the camera and it's not worth the risk.
Posted on Mar 18, 2008
What Is Alternative Financing?
normal financing is by by secured loans, personal loans or mortgage
Alternative financing is by leasing, interest only financing etc
Feb 24, 2016 | The Computers & Internet
What are the methods of cooling down an aquarium?
There are many ways you can cool-down your aquarium. You can use a simple fan that runs on timer along with the lighting. You can use a thermoelectric chiller. You can use a refrigerant base chillier and there are also some alternative methods.
Aug 13, 2012 | Fish
I have a Canon Rebel XTI and it was working fine until one day it just decided not to turn back on. Tried charging both batteries multiple times and upon putting them in, it still will not turn on. Am I...
Sorry to hear about this. I have a similar camera and have been racking my brain about this...
My only thought...are you using the same battery charger? Perhaps the battery charger is to blame. You may be out of battery on both batteries. When you install the battery, does ANYTHING happen? Does it say, LOW Battery or CHANGE the battery? Or is it totally black? If nothing happens at all, you should probably contact Canon directly. Or purchase a new charger and see if that fixes the problem.
Canon Customer Support Center Phone: 1-800-OK-CANON
1-800-652-2666 Hope this helps!
Jul 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Can CF card pin be repaired on a Canon Rebel? Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm Lens
I assume you mean one of the pins inside the camera body itself? This is quite a common problem and I believe it will have to be dealt with by a Canon Repair Centre. However it is not the end of the camera and is worth having done although I cannot say what the are charging at this time.
Sep 20, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
I have been use sony cycle Energy Rechargable batteries AA 2000mAh. They are properly charging. But now I'am purchased another sony cycle Energy Reechargable batteries AA 3000mAh. But they are no charging...
It's likely your charger. You probably own a "fast charger" but it's also probably designed for your lower mAh power batteries. The charger does not understand the power difference of your newer high-capacity battery, thus it is automatically stopping the charge before completion sensing something is wrong. You'll need to either purchase a newer charger, clearly stated capable of charging 3000mAh batteries. An alternative is to use an older "trickle" charger (one of those that charges at very low power slowly overnight). These don't automatically turn off when the battery reaches full charge, thus will charge your battery.
Sep 19, 2010 | Cameras
Canon 400d new batteries installed but will still not turn on.
Might seem obvious but check that the green light on the charging unit showed that the battery was fully charged before you put it in the camera. Make sure that the memory card is fully seated in the slot. If ok then either the charger is not charging or the on/off switch is faulty.
Jul 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Goodman a/c unit
The pressure depends greatly on the ambient temperature outside. There are two methods I use for charging a system
1. Is calculating the superheat
2. Is calculating the sub cooling.
Any good service technician will use these methods.
Jul 09, 2008 | Goodman CLQ36AR49 Air Conditioner
Charging player/downloading songs causes computer to crash.
You can purchase a "AC to USB" power adapter for about $30
Mar 04, 2008 | RCA OPAL M4001 MP3 Player
Canon Rebel XTi LCD is white
Sounds like you need to contact the Canon warranty department.
Jan 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
