Question about Kenmore 24032\24036 Top Load Washer
I can't take the washer front off to see what the problem is
I don't have any experience in this at all. how do I remove the front so I can get to the motor?
    Problem Solver:
  • 12 Answers
Most are on tabs. you have to lift up and out . kind of a pain in the butt
Posted on Feb 25, 2008
Won't drain, is there a filter on the pump?
Two things I can think of , the coupling to the pump has broken or a coin or other object has entered the pump and jammed it. either way the pump will have to be removed for repairs.
Feb 05, 2016 | Whirlpool GHW9100L Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
How to take apart will not spin out the water
I don't know your particular washer, however, have had some experience with a couple of others. I found that something got caught in the flow line to the pump (in this case one of the plastic clips that holds a bread bag closed). I tipped the washer on its side and removed the pump so I could find the blockage. The location of the pump/outlet hose will be differrent on all washers and models, however, with it tipped over or with the front or possibly the back removed it should be able to be located.
Nov 23, 2011 | General Electric WCSR2090G Top Load Washer
Samsung dryer makes loud noise; just started
'purchased approx. 2 yrs ago. always had trouble'?
Even whilst under guarantee/warantee?
I need to explain our situation.The washing machine forum is just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing mostly mechanical and electrical/electronic problems and giving guidance on these for free on the web. In addition the members are not 'affiliated' to, or representative of, any manufacturer of washing machines or detergents whatsoever so we have to be carefull what we say;-0)
Sorry but all I can suggest is that you call your local Samsung service agent to see if it can cure your problems. You do not want to go to the expense of purchasing a different washer!
If this has clarified the situation for you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 31, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
Tried washing an old rug and the backing crumbled in my Samsung WF209ANW front loading machine -- now the machine won't drain because I assume it's clogged with the debris. We cleaned the debris...
You will have to clean out the large black hose on the bottom of the tub. The only way to get to it is to remove the top cover from the washer then remove the front of the washer, after removing the front you will be able to reach in and remove the hose and clean out the rubber backing. You can try it from the back of the washer first and may have some success but from my experience you will have to go from the front maybe both. Good luck and have some towels ready to catch the water.
Nov 26, 2017 | Samsung WF209ANW 40 cu. ft. Front Load...
I have a kennmore elite front loader washer and have taken off the front bottom cover and cleaned out the drain (a pen, some coins and a clear ball) I took the hose off completely by loosening the coil...
try unplugging it and lkeave it unplugged for at least hour that should reset it ,sud of course refers to low water flow into pump but i am sure that has been resolved
Jul 20, 2011 | Kenmore Elite 45986 Front Load Washer
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
We discovered that our front door inner gasket is torn. Therefore, it's leaking during every load out of the door. I will be ordering the part but concerned that I won't be able to replace it. Do you...
If you've not done this before, expect to spend a lot of time. I've replaced these without disassembling the washer's front, but it's an arm-twisting experience to put the inner part of the gasket on, and to attach and tighten the clamp holding it. Haven't tried removing the front panel, if you can, do it - the job becomes much easier.
PS Check shocks and if the washer is leveled enough, door gaskets tear from excessive loads and excessive vibration.
Mar 29, 2010 | GE WBVH6240F Front Load Washer
TROUBLESHOOTING KENMORE ELITE HE3T FRONTLOAD WASHER WITH THE ERROR CODE F70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2009 | Kenmore Washing Machines
How do i get to the pump?
Normally there is a front lower panel that can be removed. If there isn't you will need to remove the back panel. After removing the panel you will be able to foind the pump. Make sure before you remove the hoses on the pump you get a pan to catch the water from the washer. If you don;t do this water will go everywhere.
Jul 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 24032\24036 Top Load Washer Logo
15 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
