Sharp AL-1655CS Laser Printer
Problem for Sharp AL-1655CS Laser Printer
System Error [L1-00]
By Hector_Lab on Feb 25, 2008
Make a noise then said "system error [L1-00]; REFER TO USER GUIDE
Same Problem
Oct 08, 2008
-   Dear Technical instructors,
Kindly rectify this problem on my sharp AL-1655CS printer/copier/scanner machine. It shows system error and non of the three is working.
Please rectify this for me.
Thanks
Ij-   odfij
Best Solution
posted on Apr 29, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Make sure the clear lock is unlocked where the paper comes out when copying.
Solution #2
posted on Mar 10, 2008
Helpful)
tryit
Rank: Guru  Sharp Expert
Rating: 89%, 1308 votes
L1 is an indication that the lamp carriage is not leaving the home position.
See if there is binding in the lamp, You can remove the glass WITH THE POWER REMOVED !!!! UNPLUG IT FIRST !!!!!!!!!!!
try and move the lamp by hand. Move it to the middle of the of the machine and see if it hits the sensor returning.
If it does, simply bend the bracket to allow the lamp to return to the left freely.
If it doesn't move, the lamp motor blew a fuse and needes replaced.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Aug 13, 2009
Very Helpful)
davida560
Rank: Apprentice
Rating: 100%, 6 votes
Error code L1-00 indicates that the scanner is locked down for transport. There is a dial under the scanner by the paper output tray. Rotate the dial, and the error message may be cleared. The dial controls the scanner lockdown mechanism.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #4
posted on Nov 24, 2008
Not Rated)
rogerbellamy
Rank: Apprentice
Rating: 0%, 0 votes
Ensure that not to much paper is stacked on top of the printer.... Stacked paper after long print runs and this gave the same message..
Was this helpful?
Yes
No
Solution #5
posted on May 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks, It worked.
Solution #6
posted on Mar 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
REPLACE IT FOR A NEW ONE
Popular Solutions for Sharp AL-1655CS Laser Printer
Questions and Unsolved Problems for Sharp AL-1655CS Laser Printer
Do you recommend Sharp AL-1655CS Laser Printer?
Answer
Answer
Problem with L1-00 refer to guide. Lock is unlocked, lamp carraig moves freely, drives out, then... (More)
Answer
como faco para instalar o scanner sharp al 1655
Answer
Need 64 bit driver for AL-1651CS for vista/win7
Answer
I am attempting to install the drivers for the Sharp AL-1655CS printer that is connected via the... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
