Question about Pitco Frialator SG14 Deep Fryer
Frialator will not turn on
Pilot is lit put the frilator is not turning on>
Diaphram possibly ripped or burned replace the valve assembly
Posted on Apr 11, 2008
Why won't the pilot valve turn on my pitco 35C+ frialtor?
You turn the valve knob to "Pilot", push it in, and light it (use a long butane lighter-it's easiest) and keep the button pushed in for 20 seconds-1 minute. If the pilot stays lit, turn the dial to "On".
Apr 21, 2014 | Pitco Frialator Kitchen Appliances -...
My pilot light wouldn't stay lit. After lighting the pilot for 2-3 mins. whole frialator would go off including the pilot...
Hi there. Check the hi-limit control, it may be tripping prematurely and needs replacement. Regards.
Oct 31, 2013 | Pitco Frialator 35CS Deep Fryer
How do i turn up the temperature on my pitco frilator
Hi there!
You can download owner's manual with programming guide for Pitco Frialator at www.pitco.com
Regards.
Feb 02, 2013 | Pitco Frialator SG18S Deep Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
My pitco frialator chips fryer diplaying CFG error
CFG error on controller board can be cleared by resetting the controller back to factory setting and by doing this, all program added after the factory setting will be erased so you have to reprogram them again.
Programming guides are downloadable at PITCO site on http://www.middleby.com
Jul 29, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Hello I have a Pitco Frialator 35CD Deep Fryer and as of one day ago, when I turn the wheel to turn the fire on (the wheel with the various temperatures) nothing happens? How do I fix it?
Assuming that the pilot is lit, when you turn the thermostat from off to the operating temperature, you should hear a click at some point. If you do not, the thermostat is defective. You can also double check this by detaching one of the two wires going to the thermostat and measuring for continuity between the two terminals. At off it should show no continuity. At 200F or above it should show continuity. This is the most common problem.
If the pilot will not stay lit or if it goes out when you increase the thermostat setting, it is usually a defective or weak thermopile (or thermocouple), or a defective gas valve. If replacing the gas valve, I recommend replacing the thermocouple or thermopile at the same time.
Restate your problem if the pilot won't stay lit or if it goes out when you turn the thermostat up.
Feb 11, 2010 | Pitco Frialator 35CD Deep Fryer
Frilator pilot will light but fryer wont fire up
The thermocouple or thermopile is your culprit. If it is not sending the correct millivolt signal to the main part of the gas valve telling it to open then, the burners will not light. This is the cheapest part to start with. If after changing this out & you have the same problem then, you have a bad gas valve.
Jun 28, 2009 | Pitco Frialator SG14 Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
108 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
