Question about Vacuums
Kenmore Central Vacuum System-electrical o.k. but suction function not working. No noise from canister.
  • 58 Answers
It could even be a bad motor if its an old kenmore system. If its more than 10 years old it maybe worth getting a whole new tank over just a motor.
Posted on Jul 26, 2009
    President:
  • 1,673 Answers
There should be a switch on the canister, for manual or automatic. Switch it to manual and see if it comes on. If it does, then there maybe a bad relay. If it doesn't, then there is a problem inside of it, motor, pc board, would have to be checked. Without the model number, not sure what components are inside without the model number to look it up.
Posted on Feb 26, 2008
Rattling noise beneath filter
Broken fan maybe. If the fan is has come loose from the motor shaft, it will rattle and there will be little or no suction. A trip to the local vacuum guy may be in order.
Oct 29, 2013 | Kenmore Vacuums
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Canister turns on but no suction in house
sounds like there could be a clog in the lines, Check the pipes running through your attic/basement, and see if there's something blocking the piping.
If you can't seem to find the problem, I'd suggest looking into having someone who services central vacuums come and take a look. They'd have the proper tools and knowledge to help you in person
Apr 19, 2010 | Eureka 1810 Central System Vacuum
My Kenmore Progressive is making a noise that sounds as if something is blocking the suction. I have checked the tubes and can't find any obvious blockages
Have you changed out the bag? Checked the air filters? When you run it and hold your hand over the hose opening, do you feel suction?
Check the head for blockages, you said the tubes are good, so check the hose, if no obstructions there, open the canister and check the bag, if it's full change it, if not, pull it out and check the filter that's under the bag, if it's not clogged re-run the above steps but this time look for possible vacuum leaks. Let me know if this helps.
Oct 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
We have a Kenmore canister vacuum cleaner and the power in the floor component (rotating brush, etc) is no longer functioning. The vacuum is producing suction, but does not seem to be providing power to...
the problem could be with the power head itself or the hose providing the power. If you can turn the unit on from the handle, then its not the hose and you need to get a new power head..
Aug 14, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
171 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
