Question about KitchenAid KWVU265YBA Kitchen Hood
KitchenAid KWVU265YBA I would appreciate any help you may be able to give me. I have a KitchenAid KWVU265YBA exhaust vent and the problem I'm having is that the fan unit stoped working. The Light part works fine. On the fan when I press the #1 power button nothing happens. When I press the #2 button the LED indicator light next to that #2 button comes on and I can hear a "click" in the control panel. When I push the #1 speed button or the "Off" button it shuts it down. When the #2 button is ON (and the indicator button shows it's on and I press the #3 speed button I hear that "click" noise again and then the #2 & #3 indicator lights are on at the same time and when I press the the "Off" or the #1 button it shuts them "Off". What can you determine from this. I can be emailed direct if you need to at krsent@hotmail.com. Thank you for your help.
Had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Posted on Apr 30, 2008
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
The unit has power going in but acts as if there is no power
I would be rechecking my connections fast before something catches fire
May 23, 2014 | KitchenAid KWVU265YBA Kitchen Hood
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
The unit says it is ventless yet it talks about venting into the soffitt. We have no soffitt. Do we close off both opening and thenit will recirculate?
In order for a ventless exhaust fan to function it needs to have the exterior vent opening closed off and it should then recirculate the filtered air.
Dec 15, 2010 | KitchenAid KHTU100KSS Kitchen Hood
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Vent hood not exhausting properly
you dont want to hear it but they are all the same.. the exaust fans down work to good. there isnt anything to do.
Aug 24, 2008 | Kenmore 52153 Stainless Steel Kitchen Hood
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Fan runs continually
Could be. Cut off the power first. Remove the fan box cover and discover the switch location. If you have a continuity tester, you should be able to test the switch. Sometimes, they even jam with cooking grease. If in doubt, replace it.
Nov 21, 2007 | KitchenAid KWVU265YBA Kitchen Hood
Hotpoint microwave exhaustive fan combined unit - fan not working
Do you feel air flow? That's the key.
Most microwaves have the exhaust fan assembly at the back edge, not up front immediately behind the grille / vent.
Post back if you can give us more detail or have other questions.
Oct 13, 2007 | Hotpoint RVM1635 Microwave Oven
KitchenAid KWVU265YBA Kitchen Hood Logo
612 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
