Question about Scanport N9 19" LCD Monitor
N9 LCD MONITOR
THE MONITOR JUST WENT OUT NO POWER LIGHT OR NOTHING
  • missyc62 Nov 28, 2008
    have the same problem Checked voltage @ cable lead that hooks directly to the monitor had 12 volts. Also checked with another known good monitor and power cord worked ie, monitor worked. When hooked up to bad monitor, light flashes on transformer, It glowed solid when hooked to good monitor. could this be problem.
  • fhr5 Mar 13, 2009
    I have a problem with my N9 19" monitor. From what I can tell it is either the power unit or the monitor needs to be serviced. Where can I get another adapter? Where can I have this monitor serviced and is it costly?
    Scholar:
  • 80 Answers
Hi
Check if there is power coming from the wall socket.
If the wall socket is functional, then try with another power cable.
If this also doesnt work, then the monitor has to be serviced.
Posted on Feb 25, 2008
Scanport N9 Monitor Model #M19FBK flashes one time and goes dark.
Not likely it got damaged in the move.
Make sure the plugs are firmly seated. That is, the power cord and the video plug at both ends.
Apr 18, 2010 | Scanport N9 19" LCD Monitor
I no longer have power to my monitor; is there a way to check power source or, if necessary, to buy a new power source pack?
You can measure the adapter output with a voltmeter. The output should match the voltage marked on the adapter. This model uses a 12-volt adapter.
If the adapter doesn't have any output, it may be because the wire has broken inside the cable near the plug from flexing. It's possible to repair this by soldering on a new plug. Sometimes it's tough finding the right plug, though; some brands of equipment use oddball sizes.
You can also purchase replacement adapters. Several sources came up after a search for "scanport n9 adapter". Here's one on eBay. You'll be able to find what you need.
Mar 05, 2010 | Scanport N9 19" LCD Monitor
My monitor shows a blank screen .But when I press the RGB, DVI button, I can see my desktop for a second then it stops displaying. I have to keep pressing the button to change the display type in order to...
moneyshaker, Maybe your screen (LCD panel) is not blank, just BLACK!!! First thing to do is the flashlight test! With monitor connected to a KNOWN GOOD fully booted pc with WIN-desktop showing, reconnect N9 lcd to pc. Then and only then turn on N9 lcd. Note what you see or don't see!! If screen flashes on for 1 sec and goes to BLACK, then shine a bright flashlight 1" form screen at different angles and note if you see or don't see the desktop. This is only a test to check the condition of the unit's power supply and or INVERTER circuit. If you can still see the desktop even though the screen appears BLACK, then the "switch-mode-power-supply" is only partly bad. You did not state age of your unit? Most likely your problem is that the SMPS is detecting a fault in the INVERTER circuit that provides 800 to 1200 volts to light up the "cold-cathode-fluorescent-tubes" that are hung on the rear of the Clear Glass LCD panel and in front of a mirrored reflective surface. GEE wiz If I could take these long, straight, CCFT's and turn them into coils and mate them with an electronic ballast circuit called a CONVERTER circuit (ac to ac) and put them into an oversize light bulb screw-in base I could make millions.... Oh ****, That's already been done!!!! Oh! so that's how those new CFL lamps work. I suspect that your INVERTER (dc to ac) has almost bit the dirt. It will need to be looked at by a tech type person or you could visit Youtube and chcek for video clips that deal with monitor disassembly and or repair of the 2 most common LCD monitor failures. Look under "swollen electrolytic filter capacitors" and BAD capacitors, and Poor soldering and /or poor factory oven REFLOW SOLDERING and or Thermally intermittant soldering connections on printed circuit boards. This is only a guess as to what plagues you monitor. Please rate this response on fixya if it was of any help at all. im'louie12fix on fixya or lmistyrel @aol .com
Oct 06, 2009 | Scanport N9 19" LCD Monitor
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
THANK YOU FOR YOUR FEED BACK
Possibly you can if you go to their website . FIXYA is not the manufacturer 's support
Mar 31, 2017 | Scanport N9 19" LCD Monitor
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor Failure
Your system was not affected because the PSU can prevent power surges. Your monitor's backlight has went out due to surges in electricity to your monitor. Unfortunately, you can not replace the backlight. I would suggest you buy a new monitor. 19" LCD Monitors has have went down dramatically in the past month.
Aug 25, 2007 | X2Gen MG19MY 19" LCD Monitor
Scanport N9 19" LCD Monitor Logo
147 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
