Question about GE Profile Prodigy WPSE4200A
Ge prodigy wpse4270aoww won't rinse or spin
Washer will fill, agitate, but won't rinse, empty, or spin. It just sits there and hums. Got a solution?
  • Anonymous May 10, 2008
    same model wpse4270 washer rinse cycle is ok but start spin and stop after half minut and humming noise.
  • Anonymous Feb 09, 2009
    washer will fill with water then it will just sit and hum until it gets to the drain cycle.
If basket wont spin, remove front hatch by inserting spackel knife to trip spring latch on both sides,then check the belt for wear & tear.factory length is 29.5 " time will stretch them out, resulting in broken belt.check behind control panel hatch for diagram of machine for exact location of belt also can be downloaded online.
I hope this helps.ie overloading machine will shorten belt life.
Posted on Mar 07, 2008
Try to clean out the water pump lines from pump to out to the drain
Posted on Feb 25, 2008
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Year old frigidare washer won't agitate
the selector switch might be out.
Aug 08, 2007 | Frigidaire FWTR445R
Washing Machines Logo
924 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
