Question about Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive
My drivers my driver won't burn to any staples, magnavox, or maxell dvd's since i had my box cleaned out. How do i fix this problem
    Genius:
  • 1,019 Answers
you,ve probably got a spec of dust on the laser head ?
If you took it to a shop, have they swapped the drive over, and replaced it with a dodgy one.
Shops are re-nown for doing this.
Mike @ compurepair.
Posted on Feb 25, 2008
Staplegun driver won't retract enough for staple to load
Check for a piece of a broken staple wedged in the driver slot
Jan 14, 2013 | Tools & Hardware - Others
I have a Dell inspiron 53os the cd keeps ejecting with error 2131 when trying to burn from my playlist. Ive been using Maxell CD-R's. Can you please help with this problem...
Welcome to Fixya.
Error 2131 is an error that is encountered with iTunes trying to burn a cd or dvd.
The Fix:
Update your drivers. I suggest downloading Device Doctor, a safe freeware that scans your machine and will look for the latest driver updates of the computer's devices.
1. Click Download.
2. Click Save.
3. Go to My Documents > Downloads Folder.
4. Click Device Doctor's .exe file. Installation will start.
5. After the installation, the application will scan for driver updates. Just click download.
Hope this helps. Please feel free to come back if you have further questions.
Thank you for using Fixya!
Nov 10, 2010 | Dell Computers & Internet
Why can't I burn on maxell+r, do I need a driver updute
If you have Windows XP it does not burn dvds on its own you need third party software. There are plenty of free dvd burn programs try one of them.
Jan 09, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
When i put cd-r to burn it just say need clean disk and i just brought them from staples and they showed me what i needed to burn so, what should i do or can some one go in my computer to fix it
which burn prog do use?
if it is the one that comes with windows, leave it,
install a freeware prog like Imageburn,
try to burn with this one,(doublecheck)
if still failure,
check if - cd/dvd burner works/reads other cd's properly
- the right driver (support CD!!) is installed
else plze come back with details on hardware, win version and burn program u use.
Jun 13, 2009 | Acer Aspire 5535-5050 Notebook
Emachine optiarc dvd rw ad-7200
try to go for sony rewrittable dvd and then go nero for burning it bro still i u have problem then moment while ur inserting ur dvd u will get ur option like burn the dvd and open and view the folder ok then go for it to burn the dvd
Mar 01, 2009 | E-Machines eMachines Refurbished EMA...
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Hitachi -LG GCC-4481B DVD CD-RW
If the firmware was never updated, it can cause this.
A tool like Nero infotool will show the drive firmware version or you can scan your registry for "4481" and locate an entry in <HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\DeviceClasses>
that shows the drive model and a numeric fw version.
You can go to HP http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?lc=en&cc=us&softwareitem=pv-28110-1
or to Dell http://drivers.softpedia.com/get/FIRMWARE/Others/Dell-Dimension-8300-HLDS-GCC4481-B-Firmware-28012005.shtml
and use their firmware update.
May 31, 2008 | HP 48Xx32X48X16X GCC-4481B CDRW/DVD...
Dvd player wont recognize newly burned dvd
Give this a try : write a DVD at 1x speed (lowest speed) and test it on your laptop. If this works ok then either use better media or lower (e.g half) your writing speed........
Apr 01, 2008 | Computers & Internet
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Make edits Compatible not available with +RW media
They still need to be finalised before they will work on another machine.
Dec 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Lite On (SOHC5236V) CD-RW/DVD-ROM Combo Drive Logo
57 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
