Question about Zenith A25A23W 25" TV
Vertical length I cant see the words or lower portion of pictures at the bottom of the screen, how can i shorten the screen projection so that I can see all of it. Seems that the vertical deflection length is to long. thanks
  • 62 Answers
Hiii....
I think you should check the cap around ic vertical deflection.... and see if there is have adjustment point or not ?! if you not so sure try to replace the caps and the ic too....
I'm not sure because i dont have service/manual for this model......
Hope can help you...
Thank's
[Vrya]
Posted on Feb 25, 2008
Apex ld4688
Sounds like a vertical scan out section ciruit problem. Contact any service technician.
Gopakumar Gopalan Google
Feb 25, 2014 | Televison & Video
Words at the bottom of the screen
See if you have a button called ARC on your tv remote.. you will have different modes called Wide, Zoom, normal etc., Just put it in normal mode!
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
The bottom portion of my screen is double vision witht the colors red and green only
p { margin-bottom: 0.21cm; }
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. u can see the heat sink on which the ic is mounted in the picture ( in side the small green circle). if u need more assistance feel free to contact through fixya.
regards
Ajin
Jan 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Toshiba 57H81
check closed captioning settings in the menu
Mar 31, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
