Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Sears refrigerator My freezer and refrigrator seem to working, temperature wise, but i am noticing water in the bottom of the refrigerator under the drawers. Also see water on the shelves. I turned off the water line to the ice maker and water to see if that was the problem. Still have water. any suggestions?
    Genius:
  • 1,073 Answers
Stopped up drain in the freezer remove back freezer panel and
unthaw the drain pan and the tube, the tube connects to the bottom of the metal pan, you will see a hole about the size of a dime direct the heat from the hair dryer at this hole it may take 20 min, to thaw
pour some water down the hole if it is clear of the ice the water will run to the drain pan at the bottom of the ref
if it does not keep thawing until it does
Posted on Apr 17, 2008
795.79309.901. Why is water dripping from hole on bottom back right of digital temperature control?
Drain is possibly blocked inside freezer that allows water to escape to the pan below the refrigerator. You will need to remove frozen items and remove the panel that covers the evaporator to get to it.
Leaking Refrigerators
Appliance 911 Sea Breeze
Sep 17, 2015 | Kenmore Refrigerators
Have Kenmore refrigerator and fan in freezer is not working ....any suggestions ?
Frost build up is normal... and SHOULD be expected...
You should check your DEFROST PAN at the bottom
(it should have STANDING WATER evaporating daily
(dust is usually an indication of DEFROST FAILURE
(easy to fix))
ALSO the FAN should NOT run with the door open...
My best advise ... if indeed that was ICE...
typically caused by air intrusion...
(sometimes just result of a cube stuck in the
(door service) chute.. or a pizza box holding a
door ajar (worlds will not end)))... Clear that ICE
and easily expect another 9 years of faithful service...!!
You need to allow that machine to defrost at room temperature
for as long as it takes to melt that ICE... COMPLETELY.
Helping it with a fan at ROOM TEMPERATURE is fine,,,
but ABSOLUTELY use no heated air (damage can occur).
Good temperatures in Refrigerator/Freezer sides is a
VERY GOOD indicator...
ELSE...
look over your door seals and make sure they are in full
contact ... ALL-THE-WAY-AROUND.
Comment me back...
You can do this (inexpensively)
Common Refrigerator Symptoms Symptom Diagnosis Sears PartsDirect ... SEARS parts were getting pretty competitive...
Now I cannot push it into a PRICE without talking to one of their CLOWN HEADS (pushy parts folks... My opinion).
Carnac the Magnificent
Nov 20, 2017 | Kenmore Refrigerators
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
My Kenmore Elite refrigerator doesn't cool enough, but the freezer feels ok. Here is the story: A couple of years ago I noticed that ice was accumulating at the bottom of the freezer, in a small bay...
There are two things that could be happening...
The hole is plugging up and the wtarer is not running away when it defrosts...
or the defrost control is not working correctly all of the time...
These tips cna help you to figure out the exact problem...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 07, 2010 | Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The refrigrator is warm and fills up with water.Freezer to cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Refrigrator stopped working
Morning, This seems quite a easy problem to fix.! Check to see if the f/.freezer has to compressors (motors)? If so the you find that is more than likely to be that the fridge thermostat has broken. A very easy way of checking if you electrially minded is to remove the thermostat from the housing a connect the live and common wires together and switch on, It then should switch on if there is no other problems, Then just replace the stat.
Good luck......
Dec 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
71 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
