Question about Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
Defroster leaks my refrigerator leaks water from the inside of the unit. i had an technician check the problem. he said it was the defroster that was leaking the water. what should i do? soon i'll have to replace my flooring because of the water. please help with this problem. water leaking down the left side into veg tray Whirlpool Model ET8RHMXK004. Water is not supplied to the ice maker in the top freezer. The bottom portion is dripping water from the ceiling or top down on the first shelf. Is this a defrost tube that is clogged or something??
  • 5 more comments
  • cats4 Apr 05, 2008
    I noticed water dripping from the freezer into the fridge. I also noticed ice on the top back part looking into the the refridgerator, under the freezer. What's going on?
  • jatindermana Aug 01, 2008
    I have a whirpool refrigerator and water is dipping from freezer to fridge compartment.I removed the evaporator cover to access drain hole .I have seen black cover on the drain hole.i tried but could not remove the cover from drian hole in order to clean the drain tube.
    Could u please let me know how i can remove black cover from freezer drain hole and even why the hole is covered.
  • mich2222 Jan 14, 2009
    ET1CHMXKT03, SERIAL # ER1528757
    TYPE C21TFA04
  • Anonymous Mar 21, 2014
    how do i stop water from leaking insided my refrigerator it gets into my veg drawers.
  • Anonymous Mar 23, 2014
    Whirlpool fridge EB9FVHRVS02 leaks water on floor when defrosting
  • Anonymous Mar 24, 2014
    Every 2 days when the defrost cycle goes, there a layer of ice in the front of the freezer (water had frozen) I don't see a hole where the water should be dripping down. Could something be plugged?
  • Anonymous Mar 29, 2014
    every so often i hear ice melting and water dripping in the freezer but it never leaks out. Is this normal and why is it doing this?
    President:
  • Whirlpool Master
  • 2,651 Answers
You have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
Front door of side by side is leaking water
Hello there and welcome to fixya
ok on these units there is a plastic clear water tube that is connected to a push /pull type connection under the door that will need to be checked out to see if it is leaking
Furthermore Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment.
Dec 14, 2011 | Frigidaire FRS23R4A Side by Side...
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer I have a sub zero frigerator #550 its about 15 years old....
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. .
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.You can use a hair dryer and remove the ice buildup
Oct 30, 2008 | Refrigerators
Water leaking inside the refridgerator
If your chest refrigerator is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest refrigerator but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a refrigerator. A refrigerator works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your refrigerator and place them in an alternative area to keep them frozen. Unplug and defrost your refrigerator before you do any troubleshooting or maintenance. Wipe and clean the inside of the refrigerator so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your refrigerator, you need to establish which part of the refrigerator the leak is coming from. It could be coming from the inside of the refrigerator and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your refrigerator contains a compressor which evaporates the excess water from the refrigerator. The refrigerator will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new refrigerator.
Thermostat If you refrigerator not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that you refrigerator is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer.
I hope that solution will help in solving the problem.....
Aug 08, 2011 | Whirlpool ET1FHTXM Top Freezer...
Water is leaking from under the fridge
If your chest refrigerator is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty refrigerator but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
There are not that many serviceable or changeable parts inside a refrigerator. A refrigerator works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a refrigerator but some of them are not serviceable.
Defrosting
Remove the contents of your refrigerator and place them in an alternative area to keep them frozen. Unplug and defrost your chest refrigerator before you do any troubleshooting or maintenance. Wipe and clean the inside of the refrigerator so that when you plug it back in it, will free of any grime or loose bits of debris. A clean refrigerator will also help to promote visibility when it comes to fixing leaks.
Where is the Leak?
Once you have defrosted your refrigerator, you need to establish which part of the refrigerator the leak is coming from. It could be coming from the inside of the refrigerator and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the refrigerator. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the refrigerator. You will probably have to unscrew or un clip the backing panel.
If the drain hole on your refrigerator has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest refrigerator. The drain hole is a component within the lower works of the refrigerator through which excess water runs to be recycled.
Compressor Issues
Thermostat
If your refrigerator is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your refrigerator is cycling correctly prior to making changes or altering the thermostat. Only if the refrigerator is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your refrigerator and you still cannot locate the leak, calling in a service technician might be the best answer.
Hope this will help in solving....
May 07, 2011 | Maytag Refrigerators
Our frig. Leaks a small amount of water from inside about every 3 days
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination.... This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Leak
It leaks Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Defroster leaks
the defrost water usually goes down a tube underneath the frig & ends up in a pan near the compressor. more than likely the tube is clogged. water or air pressure in either direction of the tube should solve your problem. hope this helps.
Nov 02, 2007 | Refrigerators
Defroster leaks
is the drain hole at the inside/back of the fridge blocked? check that you do not push foodstuffs too far back against the wall, and is there excess condensation from veg etc?
May 29, 2007 | GE PTS22SCRBS Top Freezer Refrigerator...
Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
508 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
