Sounds like either a loose connection suspected from the fault worsening when you moved it, or a dry solder joint on one of the pcbs. It could also be a dry capacitor on the power supply board shown by bulging tops on the capacitor. It could be that when mounted on the wall, the tv was located near a source of heat and this heat helped the low value capacitors to warm up and work. Either way it will be one of these 3 possible solutions.
