Amana washer Hi, I have a 9yr old amana washer model # lwa30aw that is leaking at the bottom main seal, I have a kit that has the seals to fix it. I need to know how to get the agitator out there are no hex nuts in the side of the agitator and no nuts in the inside of the top of the agitator. can you help Kyle
    President:
  • Washing Mach... Master
  • 2,651 Answers
PULL,PULL. turn your head and pull!!!!!!!!!, your also gonna need some adhesive for that seal kit silicone wont work
Posted on Feb 25, 2008
Water is leaking from top loading frigidaire crown washer
go on line find model number on the back of washer
you should be able to fine seal kit and yes a new seal kit well do the job you well have to remove the drum unclamp hoses and remove you may want to have repairman come do this.
Nov 25, 2009 | Washing Machines
Amana commercial quality washer lwa30aw owners manual
Try Googling (amana)(wa30aw)(manual) without parens.
Jan 01, 2018 | Amana Washing Machines
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Leaking/ loud
Well the tub seal actually has the bearings inside of it. You can purchase one as a seal kit. However, replacing one requires specialty tools. I do not have the part numbers, but I do have a solution. Go to a local appliance parts store with your model and serial number (these should be located on the top rear side of the console) Tell them you need a seal kit for that model / serial number. When they bring it up, there are step by step instructions of how to replace your bearing seal inside the parts box. On the instruction sheet on the first page, it tells you what tools you'll need to do the job including the specialty tools and thier manufactures parts numbers so you can purchase them there or have them ordered.
May 28, 2008 | Amana NAV5800A Top Load Washer
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
Leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at familyappliancerepair@yahoo.com
Dec 06, 2007 | Amana ALW480DA Top Load Washer
Amana washer "goo" on clothes?
Ann, these Amana's are the mother of all washers to change out the seal and bearings. It's possible you just have a lot of gunk built up on the inside of the basket from years of washing. I would not put a cent into it. You are better off getting a new direct drive washer. Catriver...post back.
Oct 08, 2006 | Amana NAV3335A Top Load Washer
Washing Machines Logo
312 people viewed this question
Top Washing Machines Experts
