Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
VGA to SHARP flat sreen tv
Hey! I need help!! How do I How to connect my VGA to my SHARP flat screen t.v.?
  • Anonymous Mar 14, 2014
    it is a sharp regular tv not flat screen
  • 298 Answers
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Posted on Feb 25, 2008
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Im trying to connect my laptop to my TV, laptop end is a VGA and tv is HDMI. i also have a cord that does VGA on laptop Component on TV..neither will work.. whats the problem?
Hey Erin, when you mean it does not work as in there is nothing on the screen including audio? With VGA to HDMI (assuming you have the VGA to HDMI adapter) you should only get video since VGA does not support sound. As far as connecting goes its pretty much plug and play. That's also assuming that you have set it to the correct input on your tv and make sure your laptop has proper settings. Go to control panel and go to display. Make sure it recognizes dual monitor. Other than that there really should not be a problem. Look at video input on tv and display settings (OR mobile pc > windows mobility center > connect to a projector or other external display (not under classic view - Vista). I hope this helps. Give me a feedback if not. Good luck Erin.
- Joe.
Oct 22, 2013 | Televison & Video
My aftron lcd have problem with screen it opens for seconds and become black screen even i choose source like AV,TV,VGA it doesn't work what can i do pls
Do you have a device inputting into the port you are selecting ?
Try connecting the VGA port on TV to your PC's out put where the monitor connects, Boot the PC after selecting VGA as the input on the TV. Your PC's desktop should be displayed on the TV's screen
Oct 16, 2013 | Sharp R-510HW Microwave Oven
55"sharp aquos led flat sreen and its making a
Can it be heard with sound off and describe the sound a bit, buzz or high pitched sound? Not unusual for the front screen unit to make a slight buzz but I gather this is loud.
Dec 13, 2012 | Televison & Video
How do I get my Toshiba Laptop to project on the Sharp TV I connected the VGA cord?
Tries connect it with HDMI cable to tv HDMI hub to the Laptop USB hub this the best result,not many problems with capatabilities this way.
Jul 06, 2010 | LG 32LG30 32 in. LCD HDTV
I am trying to connect my MacBook Pro to my TV
You have to go to System Preferences, Display and then choose display, arrangement and then check the box mirror images. If you have done that, and it still doesn't work, then I'm not sure what else to do! I hope that helps.
Apr 03, 2010 | Sharp AQUOS LC-20S5U 20 in. EDTV-Ready LCD...
My child break the sreen with a toy can i fixed
it can be fixed. Its a matter of getting another screen and then replace it.
The problem would be the availability of the screen and the cost.
You can check from sharp store or any electronic shop within your vicinity for the screen.
The cost of the screen will determine whether you should buy the screen or replace the TV.
Best regards.
Feb 25, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sreen not broke but the picture inside is when
If you see rainbow colors on the screen, the screen is cracked, you will need the whole panel assembly replaced.
Nov 03, 2009 | Sharp LC46SB54U 46 in. LCD TV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
914 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
