HP Compaq ProLiant DL380 G4 Server Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a BIOS setting on the DL380 G4 that needs to be changed to allow it to boot from DVD?
electronic & computer repair& servicre
Level 3:
  • HP Master 12,061 Answers
  • Posted on Feb 13, 2010
HP Master
Level 3:
Answers
12061
Questions
0
Helped
4008172
Points
36390
Please check in your BIOS and see if that "Function" is available, usually it is. Otherwise it makes it real hard to do anything. However what we used to do in "The Old Days" in a machine that didn't, was to do an install on another very similar machine, also place on it, ALL necessary "Drivers" for the actual machine you will be using & transfer to a Directory, on the new machine. Then on the new machine, at FIRST Bootup, boot in SAFE MODE and Rip all the Drivers out of Device Manager, and reboot, NOW it will detect the new hardware and ask for Drivers, point them to the place you had prepared for them and Install. A bit of work.. but gets there in the end. Don't forget USB Flash Drives as well.
HP DL160 g6 need to activate boot from DVD
Hi Fyamine,
While booting go into the BIOS, use either the dedicated keys or +/- to enable/disable the CD ROM boot ( in the Advanced section of device management), then go into the advanced boot tab and change the boot order (it should be CD->HDD->Pxe->Disabled by Default). After that, restart the server and wait for it to boot from the disk.
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
2answers
HP Compaq ProLiant DL380 G2 Server won't boot from cdrom
Hello, I think you might find more information on starting up the DL380 G2 at the link shown below:
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c00972124
Also, the replacement instructions, in case it needs to be replaced, (and relevant troubleshooting info) for the 5i controller are found in the link here :http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=316587&docLocale=en_US&docId=emr_na-c00688182
Please first make sure that you are using the proper startup boot disk for the server before entering the CD ROM option from the boot menu. Also, check the front panel of the SCSI drives for any errors or blinking LEDS that correspond to an error code. You can run a diagnostics CD/DVD that arrived with the manufacturer's pack to detect any raid issues on startup.
If you are still facing difficulties with booting up the server, you can find a video for replacement of the appropriate scsi drive here if you are still facing any issues of your scsi drive. Try a different hard disk or check the relevant diagnostics to verify whether is the controller or the drive that complicates the booting of the server
For more details check the scsi manual in the link below (section "FBWC LEDs" , pages 15-17).
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c04441382
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
1helpful
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
HP DL380 G4 could not boot up. Nothing display as well. What's wrong with that?
make sure there is no disk in cd rom drive if there remove it and also check the amber led in front panel which is indicating the problem still if you are not able then open it and check the ram. And the power connector in motherboard and also the cmos battery or reset the bios.
Erorr 805 processor not supported
Is your server under carePAQ/ support by HP.
Please go to the System Settings/BIOS of the server by pressing F9 while booting. Check for error messages.
Please check for the processor support matrix also. You may want to try upgrading the motherborad firmware berfore loading this proc.
Cheers,
2answers
Boot problem with a ProLiant DL 380 server,
To enter the BIOS of a ProLiant DL380 you have to press "F9"
Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
